Old 09-13-2016, 05:43 PM   #1
How can I tell if I have a fiberglass roof?
I have a 2014 Sunseeker 2860DS and it seems like a fiberglass roof and not a rubber roof. But a guy at the parts counter of an RV dealer said he thought it would be a rubber roof. They sell Sunseeker so it seems like he should know but it would not surprise me that he doesn't.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
gmacklem is offline   Reply With Quote
Old 09-13-2016, 08:39 PM   #2
I ha e the same year and model and I am pretty darn sure it's fiberglass.
Pacostaco is offline   Reply With Quote
Old 09-13-2016, 09:01 PM   #3
bubbles's Avatar
If you can't tell by just looking at it (smooth, rubber vs wrinkly, fg) tap on it with a coin. Rubber will be a dull thud and fg will have a click sound.
Old 09-13-2016, 09:31 PM   #4
Mine looks like some sort of mesh
Also couldnt figure it out
Aztec1382 is offline   Reply With Quote
Old 09-14-2016, 06:17 AM   #5
Mine seems hard, but has a textured surface. Are the rubber roofs smooth? I have a Sunseeker brochure that doesn't have any model year info on it that states they have a fiberglass roof. I want to confirm what I have before I use acetone to clean the Dicor and apply the Eternabond tape.
Old 09-14-2016, 08:32 AM   #6
bubbles's Avatar
I believe there are 2 types of rubber roof material used; EPDM and TPO. EPDM will have a black underside and TPO will be the same color on both sides. One way to tell could be by removing the 4 screws that hold a fan or vent inside bezel to see if the material is wrapped around the opening and stapled to the inside ceiling. If it is, it's rubber. FG will be cut flush with opening.
Old 09-14-2016, 10:24 AM   #7
I'm quite sure yours has a fiberglass roof. My 2015 Sunseeker does. It appears like a "pebble" surface. Acetone is fine for the surface.
swuebbels is offline   Reply With Quote
Old 09-14-2016, 02:11 PM   #8
Class C Representative
Joshua Cavitt's Avatar
You have a Fiberglass roof.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 09-14-2016, 04:10 PM   #9
Thanks, I was hoping you would chime in.
Old 09-16-2016, 09:29 AM   #10
Wolverine 1945's Avatar
We have a 2013 Sunseeker,,, the roof is not rubber !!!
Fiberglass I guess ???
Wolverine 1945 is offline   Reply With Quote
Old 09-16-2016, 05:15 PM   #11
Mine is a 2012 and it's fiberglass
aemail4sue is offline   Reply With Quote
fiberglass, roo, roof
