Old 05-04-2012, 04:16 PM   #1
Question How do you remove draws under sink in 2012 3170
I cant release the draw under kitchen sink, so I can reach hot water heater lines. Anyone known how?
badboy267 is offline   Reply With Quote
Old 05-04-2012, 05:42 PM   #2
jtstromsburg's Avatar
Got a picture of the slides? Might help to see the style.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-04-2012, 05:52 PM   #3
No,I will have to take one.
Old 05-04-2012, 06:19 PM   #4
If its like mine, pull the drawer part way out. Look at the slides and you will see a black piece of plastic in the middle of the slide. Push down on it (one on each side) and continue pulling the drawer out. The parts of the slide attached to the drawer and the cabinet will separate. To reattach just line up the slides and push back in.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 05-04-2012, 06:42 PM   #5
RvBill3 You are the man! Right on the money Thanks!!
Dan and Nancy
2012 Sunseeker 3170DS/Ford E450
2016 nights camped (53)
Old 06-18-2013, 05:06 PM   #6
But...
Looked up this tread and tried to pull out one of the drawers in my 2703ws kitchen. I can get the latch to release on the right side but not on the left side and it's the same on all of the drawers!
Anybody have any ideas?
wyoman is offline   Reply With Quote
Old 06-19-2013, 06:12 AM   #7
Pull it open and locate the black plastic pieces on the metal slides, then try pushing one side down and pulling up on the other side while pulling the drawer out.
Dan and Nancy
Old 06-19-2013, 08:28 AM   #8
Another Thread
Thanks for the reply. Not long after I posted, I found another thread that said as you describe and I had no trouble. I couldn't find this thread to post an "I found it." note.
This forum is a real boon to all Forest River owners.
wyoman
Old 06-19-2013, 09:30 AM   #9
GM
bclemens's Avatar
The slides are ambidextrous? standardized? uniform?...Anyway it doesn't matter if you put one on the right and one on the left....they are all the same, but that means one of them is always upside down when they're mounted. The black lever to disengage the slide ALWAYS needs to be pushed down...unless of course the slide is installed upside down (which will be at least one on every pair). That side goes up.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
