Old 05-08-2016, 08:25 PM   #1
How many qts of oil in the Ford V10?
I downloaded a PDF manual for the Ford E-450 with the V10. It states that the engine takes 6 qts of oil. When I changed it recently, 6 qts only put the level just over half way between the two holes in the dipstick. The oil filter does seem to be on a remote mount, did Sunseeker add that? Does it add more capacity?
Thanks.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 05-08-2016, 08:52 PM   #2
Garrette's Avatar
6qts. 7qts will overfill. If you are concerned, drain, change filter, add 6, crank to fill filter, give time to drain, check. Add just enough to bring it to the stick where you want it.
My question is this, I have a riveted 2 piece dip stick, wonder if they are the same length.
Filter is a remote mount, drivers side. I assume it is a ford placement.
Garrette is offline   Reply With Quote
Old 05-09-2016, 07:25 AM   #3
6.5 quarts with a filter change.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 05-10-2016, 03:33 PM   #4
And for all us that use metric 5.7 liters
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 05-10-2016, 03:47 PM   #5
VinceU's Avatar
You folks are assuming the dipstick is correct! The engine block is more accurate and quantity established by Ford. Excess level will allow foaming and engine damage. E450 calls for 6 quarts, F53 is 7 quarts. Your rig, suggest tread lightly when reengineering.
VinceU is online now   Reply With Quote
Old 05-11-2016, 11:55 AM   #6
mike.t's Avatar
#1What does "You folks are assuming the dipstick is correct" mean??
#2 What does "suggest tread lightly when reengineering" mean??
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-12-2016, 07:04 AM   #7
Wolverine 1945's Avatar
I guess they think that maybe FR moved the Oil Filter ???
Wolverine 1945 is offline   Reply With Quote
Old 05-12-2016, 09:31 AM   #8
mike.t's Avatar
I guess. Strange. And I am not going to try to figure out
"The engine block is more accurate and quantity established by Ford".
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-12-2016, 11:16 AM   #9
Delco Bobby's Avatar
I have read too many stories where an engine had the wrong dip stick installed. Some seem to have happened at the factory but others may have happened afterwards during a previous service visit.
Do the Ford dipsticks have a part number on them? If so, check to confirm that you have the correct dipstick for your engine. If not, try to compare your dip stick to a brand new vehicle which may confirm that you have the correct version.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 05-12-2016, 12:20 PM   #10
Don't sweat it. The V-10 is very forgiving, 6.5-7 is fine. I always use 7qts in mine but I let it drain for along time as the oil cooler holds a bit. Always at the upper limit when I'm done.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
ford
