Old 06-02-2015, 11:53 AM   #11
Tinkerer and Putterer
The folks at the factory supported it from the bottom, clamped the plastic, a metal strip and the RV sidewall together and then sent some fresh screws through it to put things right.
HappyGuy is offline   Reply With Quote
Old 06-03-2015, 08:33 PM   #12
Our 2011 3170DS rear pass through storage bay was sagging abit in the middle... We use the rear bay for just about everything... Easy up, folding tables, zero gravity chairs, homemade wood leveling ramps, list goes on and on.
About 3 years ago I noticed the sagging in the middle between driver side and passanger side was causing the edges to pull away some. I added two angle iron (boxed the end where it goes over frame) that goes all the way across. Tack welded to the frame. Everything sucked back up and bay has not de-formed again.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 06-03-2015, 09:44 PM   #13
Garrette's Avatar
Be to see posted pictures of this mode. I need to do the same thing.
Garrette is offline   Reply With Quote
Old 06-04-2015, 10:54 AM   #14
Me 3!! I've thought about doing something simliar as mine sags alot, now I have more motivation before my next trip. (dry camping for 6 days, there will be alot of firewood back there)
thanks
2011 Forester 3171DS Pic
torino421 is offline   Reply With Quote
Old 06-04-2015, 08:28 PM   #15
Pics
Old 06-04-2015, 08:36 PM   #16
Pics
Now with pics
ID:	79056   Click image for larger version
Old 06-06-2015, 03:31 PM   #17
I slipped some 2x4's between the frame rails and the floor of the rear compartment of our 3100. I made some clamps to hold them in place.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
weight
