Old 11-30-2015, 06:25 PM   #1
How to add water to these batteries?
I have the generic black batteries with no markings that came from the factory. How do you check/add water to these? It looks like the cap should come off somehow, but I can't figure it out...I don't want to pry hard enough to do damage....
rad_jr is offline   Reply With Quote
Old 11-30-2015, 06:31 PM   #2
A32Deuce's Avatar
Picture of top of Bats would help. Should be 2 oval covers about mid point of bat. the pry up if that's what you have. Then fill as needed with distilled water.
A32Deuce is offline   Reply With Quote
Old 11-30-2015, 06:33 PM   #3
These are the batteries...seems like the half opposite the lugs should come off?
Old 11-30-2015, 06:37 PM   #4
Ford Idaho's Avatar
Those look like AGM's, no water needed.
Old 11-30-2015, 07:06 PM   #5
A32Deuce's Avatar
That's what they look like to me.
Old 11-30-2015, 07:46 PM   #6
Thanks for posting!
My batteries look the same in my 2015 3170ds and I wasn't sure either.
6inthefamily is offline   Reply With Quote
Old 11-30-2015, 08:35 PM   #7
Definately not AGM's...I can hear the water sloshing around inside when I move them...label on top says not to tip them and keep the vent cap level and tight.
Old 11-30-2015, 08:38 PM   #8
Kenny kustom's Avatar
" maintenance free"
Non fill able. ( unless you are very persistent. )
2017 Dynamax Isata 4
Old 12-01-2015, 01:04 PM   #9
SlowrideHD's Avatar
You might be able to pry that part up. The hard part will be to seal it back together. Are they bad?
What does the voltage check?
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 12-01-2015, 01:23 PM   #10
Have had same battery in my Sunseeker. Don't bother with water. Replace the batteries with Interstates or better. Factory batteries are bad news.
RubberNail is offline   Reply With Quote
water, battery
