Old 05-02-2018, 10:56 AM   #1
How to remove the screen from living room vent on a 2017 2800qs mh
The screens in our 2800qs 2017 are getting clogged by lint. How can the screens be removed or how do you clean your vents?
Tom C 47 is offline   Reply With Quote
Old 05-02-2018, 11:28 AM   #2
I open the vent and use the shopvac or small vacuum on reverse to blow all the crap out of the vent....
Phil
PhilG is offline   Reply With Quote
Old 05-02-2018, 12:32 PM   #3
Phil
This is the screen below fan that needs cleanedClick image for larger version
Old 05-02-2018, 01:12 PM   #4
Duckogram's Avatar
That is a maxxfan. The 4 little “L” clips turn and the screen will fall on your head.
Edit: No tools needed. Just pull down gently as you turn.
ILB ( | )
Old 05-02-2018, 01:21 PM   #5
Yep... what Duckogram said.
We remove and clean ours pretty regularly.
A soft bristle dust brush works great. (outside of course)
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 05-03-2018, 08:11 PM   #6
Villagerjjm's Avatar
Ahh... a QUESTION !!!!
If you go to a store that sells paint, you will find a pad that has two rollers on it that is used for trim work and edging. I use one of those to clean my screens. I use a solution of 16 oz bottle of water with TWO drops of DAWN dishsoap mixed in. It cleans all the screens and the air conditioner filters nicely. After the screens have dried, I will go over them with another pad treated with insecticide to keep away any unwanted bugz. You could also use RAIN-X to shed away any rain (or bugz) on the outside screens.
Villagerjjm is offline   Reply With Quote
280, roo, vent
