Old 08-09-2015, 02:16 PM   #1
How to remove wheel simulator/hub cap from the wheel?
I was putting air in my tires this morning and dropped one of the steel caps from the valve stem. I think it went between the wheel and the wheel simulator. I also found out I don't know how to remove the wheel simulator. So how do these things come off?
Thanks.
Greg
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
gmacklem is offline   Reply With Quote
Old 08-09-2015, 02:23 PM   #2
Average Joe
MrJoe's Avatar
Working around the wheel, pry it off with a flat screwdriver. Don't just pry in one spot or you'll bend the simulator.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 08-09-2015, 04:08 PM   #3
Garrette's Avatar
Claw hammer. Be careful not to bend.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-09-2015, 04:37 PM   #4
I tried that and it did not want to budge so I decided to wait and ask here to make sure I was doing it right. Will try again next weekend at the storage lot.
Old 08-09-2015, 05:28 PM   #5
xman123's Avatar
Tap on lugs three are attached take those off with proper socket
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
xman123 is offline   Reply With Quote
Old 08-09-2015, 06:59 PM   #6
Average Joe
MrJoe's Avatar
My Sunseeker is different than this. Mine is just like a hubcap.
Joe and Karen
Old 08-09-2015, 07:07 PM   #7
Thanks.
Greg
Like others have said they come off like a regular hubcap, on the sunseeker.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 08-10-2015, 08:25 AM   #8
Wait till next year...
n-e-d's Avatar
X 2 Claw Hammer works just be careful about bending edge and work your way around slowly
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
n-e-d is offline   Reply With Quote
Old 08-10-2015, 08:32 AM   #9
2013leprechaun319dsf's Avatar
I bought a little L shaped nail remover, about 10" long, and pry in 2 or 3 places and it pops right off. Use my hand or a rubber mallet to put it back on.
2013leprechaun319dsf is offline   Reply With Quote
Old 08-10-2015, 08:43 AM   #10
Jim Schings's Avatar
DO NOT PRY YET! 3 of the 10 chrome lug nut covers are actually threaded and hold the simulator on. On mine you MUST remove them first or you will destroy the simulator. Look closely at the lug not covers. 3 of them are slightly different at the bottom. You SHOULD have received a tool to remove those 3 first. It is possible you don't have this type, however CHECK.
Jim Schings is offline   Reply With Quote
Old 08-10-2015, 08:59 AM   #11
bubbles's Avatar
If your simulators are this kind there will be an indentation near the base of the lug nut covers that need to be removed with the special tool that should have been provided to you. Could be 2 or 3 have to be removed. then the simulator will pop off.
Old 08-10-2015, 11:35 AM   #12
The video I found on YouTube for a horse trailer showed that as well. I couldn't find much else about these wheel caps. I will check to see if some of the lug nut covers screw off before I start prying.
Old 08-10-2015, 11:36 AM   #13
RedLdr1's Avatar
Go to Northern Tools, Ebay or your local automotive store and pick up a Grip Tools Tire and Hub Cap Remover, Model# 52114. See Here. They make the job a lot easier and you are less likely to bend the hub cap / simulator taking it off and putting it back on....
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 chassis on order.
2024 Coachmen Northern Spirit 1943RB
2021 F-150 4X2 SuperCrew Lariat 502A, 3.5L Powerboost Hybrid, 3.55 gears, Tow Technology Package, Tow Mirrors, 1,840# Cargo, 7,000# Tow, 7.2KW Pro Power, Sumo Springs, A.R.E. Z2 Topper
It is better to have too much truck than to have too much trailer.
RedLdr1 is offline   Reply With Quote
Old 08-10-2015, 11:40 AM   #14
Harbor Freight or similar carries what is called a rolling bar one end has a hook works great I had only from my Mill right days.
Myrle is offline   Reply With Quote
Old 08-12-2015, 07:05 PM   #15
Harbor Freight has this tool also. Works great at removing and replacing. Just pry around the rim in several spots and it will finally just pop off. Putting it back, make sure it is lined up properly (the fake lug nuts positioned over the real ones) and use the mallet end to hammer on in several places. Takes a little effort, but will eventually pop into place.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 08-12-2015, 10:30 PM   #16
benagi's Avatar
Our 1997 Minnie Winnie had a couple of lug caps you had to take off before removing the beauty ring. Does anyone know for sure whether the 3170 or 3171 do or do not have lug caps that need removing before prying?
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 08-13-2015, 09:39 PM   #17
Garrette's Avatar
My 2014 3170DSF, the wheel covers are one piece and just pop off with a little effort.
Old 08-14-2015, 07:00 AM   #18
You may or may not have this type.
It is easy to see. Just look closely at the faux lug nut covers. 2 or three of them will be different at the base where they meet the chrome flat section. If you have them you will need to turn them off first. Then the wheel cover will fall right off.
Old 08-14-2015, 08:08 PM   #19
benagi's Avatar
Jim, I did look at them closely, and they all look the same to me. I think they are the same as Garrett's wheel covers. Should be safe to pull off with one of the above pictured tools.
1968 tent trailer
1985 Jamboree 23 ft
wheel
