Old 05-29-2015, 02:32 PM   #11
Originally Posted by Jim in Halifax View Post
Drill a small hole with a 1/116" drill bit (or smaller) at the end of the crack.....Put some instant "ca" glue in crack and then some car wax.....J
Another thought.....after drilling hole remove lock from door and install a decal - sticker over the fix and then install the lock again....J
Jim in Halifax is online now   Reply With Quote
Old 06-01-2015, 08:15 PM   #12
I suggest you not use silicone for any repair. Nothing will stick to silicone if you need to add anything on top of it.
budblack is offline   Reply With Quote
door, repair
