Old 05-28-2015, 07:22 PM   #1
How to repair small crack in basement hatch door?
Ok, I made a newbie mistake with my new to me Sunseeker. I put the bedroom slide in with the basement hatch door up. It closed on the hatch and caused the latch to crack the fiberglass panel at the latch. So what can I do to fix it? I am mainly worried about water intrusion as I assume the door has wood inside? Can I put a layer of clear caulk over it?
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 05-28-2015, 07:24 PM   #2
Photo?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 05-28-2015, 07:26 PM   #3
Originally Posted by Toddupton View Post
Photo?
No photo, will take one this weekend though I hoped to repair it this weekend. It is two small, 1 to 2 inch cracks extending from the latch.
Old 05-28-2015, 07:29 PM   #4
tmhyer's Avatar
I'd atleast apply clear silicone to it
tmhyer is offline   Reply With Quote
Old 05-29-2015, 01:14 PM   #5
GM
bclemens's Avatar
Or some tape for a quick fix. Just bondo, sand, paint, clear like any gel coat fiberglass.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 05-29-2015, 01:14 PM   #6
I have used Flex Seal on my RV, just don't go crazy with it.
btritschler1437 is offline   Reply With Quote
Old 05-29-2015, 01:23 PM   #7
Don't use caulking or Flex seal or bondo. This is fiberglass with a gelco finish much like a boat has. Go to your local boat supply shop and ask for gelco patch. You can get many colors and it mix and applies easy. Then you sand with 2000 grit paper to a matching finish. May take a little extra time but will be permanent fix.
j free is offline   Reply With Quote
Old 05-29-2015, 01:43 PM   #8
Drill a small hole with a 1/116" drill bit (or smaller) at the end of the crack.....Put some instant "ca" glue in crack and then some car wax.....J
Jim in Halifax is online now   Reply With Quote
Old 05-29-2015, 02:18 PM   #9
This sounds promising. The coach only has 5,000 miles and I hope to have it for years and hate to have an ugly patch already. Will check into this and see if I can make it at least not too visible.
Old 05-29-2015, 02:21 PM   #10
GM
bclemens's Avatar
Sorry, that's what I meant. We still call it bondo here...just so used to the term.
door, repair
