Old 10-03-2016, 01:26 PM   #1
How to run an additional 12v DC
Installed a new King Jack antenna today and I need an additional 12v DC for the install. Currently there is a 12v DC for the TV. Can I just splice into that wiring and hook up the power to the antenna, or do I need to run new wiring from the battery? Thanks for your help!
lexstone is offline   Reply With Quote
Old 10-04-2016, 04:52 PM   #2
You first need to check the total amps load on the fuse supplying the TV and decide if you can add the load of your new device.
I don't know what RV you have, but I think Sunseekers and Foresters have 12 volts to every roof vent to make it easy to install vent fans. It may be easier to get 12 volts from a roof vent than from the TV. You can easily drop the vent's interior trim to see if a wire is there.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 10-04-2016, 06:45 PM   #3
We have a 2013, Sunseeker 2300. Thanks for the advice!
Old 10-04-2016, 07:58 PM   #4
Are you replacing the standard antenna? There is 12 volts supplied to the amplifier on the standard antenna. Remove the cover plate that has the antenna connector and you will find an amplifier with 12 volt wiring.
2012 Sunseeker 2300 Chevy
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 10-06-2016, 02:48 AM   #5
DouglasReid's Avatar
Are you certain yoru TV is 12 Volt, most are 120 Volt.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 10-06-2016, 06:30 AM   #6
Wolverine 1945's Avatar
Our 2013 Sunseeker came with a 12 volt DC TV !!!
Wolverine 1945 is offline   Reply With Quote
Old 10-06-2016, 06:50 AM   #7
Yes, we two 12v TVs. I have both devices hooked up to the standard TV outlet. I was concerned that it may be too many amps for the circuit. Does anyone know how many amps the Jensen TV pulls off that circuit?
Old 10-06-2016, 07:02 AM   #8
If you Google it you will find a lot of info,,, one thing I saw said TV jack has a 5 amp fuse ???
Old 10-06-2016, 07:08 AM   #9
Oh okay great idea! Thanks
Old 10-06-2016, 09:27 PM   #10
My 3010DS has three TV's and they are all 12v.
kins83 is offline   Reply With Quote
