01-15-2015, 08:58 PM
How's this happen? Gain 600 lbs. in a year
Perusing through the 2014 Sunseeker and the 2015 Sunseeker sales brouchures. The 3100 SS model gained 600 lbs. in the past year in UVW. Doesn't look any different and doesn't appear to have any substantial material or equipment changes from 2014-2015. Are these weights accurate? Are any actual units weighed at the factory for realistic weight
statistics?
2014 stats. 11,900 UVW
2015 stats. 12,500 UVW
01-17-2015, 09:11 AM
Commercial Member
Could be an error. I'll have to check my engineering specs.
01-17-2015, 10:20 AM
I read on this forum that FR weighs each Class C when it is complete, so the cargo capacity on the door sticker is correct for the vehicle. It is not based on a sample vehicle with the weight of options added to the sample weight, which may or may not be accurate.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
01-17-2015, 10:37 AM
Commercial Member
Last brochure the 3100 got left off. This year when the printer added it back, instead of going off the specs I gave him, looks like he just copied the 3170 over.
01-18-2015, 07:52 AM
Well, that is where I'm a bit confused. The top pic in post #1 is from the 2014 sales brochure. Do MH manufacturers really weigh these units? Just a couple? Or everyone as someone stated above? Thanks for the response.
01-18-2015, 08:52 AM
Every single unit is weighed.
01-18-2015, 08:59 AM
Always Learning
Yes, all units are weighed. There was a recent picture on XLR's Facebook page of their factory build process and it included their scales setup.
I would assume the brochure weights are from a combination of engineering drawings and weighing prototype unit(s).
01-18-2015, 09:29 AM
^^Good info. Thanks.
01-19-2015, 11:54 AM
I think it all depends on what is added? another chair? Dual air conditioning? Chrome wheels instead of aluminum. It all adds up to added weight. This is why each unit is measured specifically when it leaves the factory. I believe that the label is printed for each unit as it leaves the assembly line.
01-19-2015, 12:02 PM
Commercial Member
Nothing was added, this is just an error. Brochure guy thought the 3100 was coming out for some reason. When I added it back in it looks like he just copied over the 3170 and never changed the data. It will be corrected on the next printing.
Correct Specs:
FORD CHASSIS
WHEELBASE 220"
GVWR 14500
GAWRR 9600
GAWRF 5000
UVW 11900
GCWR 22000
NCC 2600
FUEL CAPACITY (GAL) 55
HITCH RATING 7500/500
LENGTH - BUMPER TO BUMPER 31'-11"
CAPACITIES & DIMENSIONS
EXTERIOR HEIGHT WITH A/C 11'-3"
EXTERIOR WIDTH 101"
INTERIOR WIDTH 95.5"
INTERIOR HEIGHT FRT/REAR 84"/77"
FRESH WATER (GAL) 44
GREY WATER (GAL) 39
BLACK WATER (GAL) 39
L.P. CAPACITY (GAL) 9.8
AWNING LENGTH 16'
WATER HEATER (GAL) 6
EXTERIOR STORAGE (CU. FT.) 129.2
FURNACE SIZE (BTU) 30000
CONVERTER SIZE (AMP) 60
REFER SIZE (CU. FT) 6
SOFA SIZE (OVERALL) 67"
DINETTE SIZE 44x68
DOUBLE/QUEEN BED SIZE 60x74
TWIN/BUNK BED SIZE 32x74
CABOVER BED SIZE 60x80
SEAT BELTS - STD 8
SEAT BELTS - OPT NA
