Old 03-19-2018, 08:41 AM   #1
Santabobswife's Avatar
Ice maker in 2018
The ice maker in our new 2018 Sunseeker 3050S is not filling with water. DH filled with some water and it cycled to dump the ice so it must be in the fill. Any suggestions. Don't see suggestions in manual.
Santabobswife
Bob, Diane & Snoopy
2018 3050s Sunseeker
Santabobswife is offline   Reply With Quote
Old 03-19-2018, 09:26 AM   #2
Just a couple of points.
The ice maker will only operate when on shore/generator power.
Make sure that you are connected to city water (turned on) or have the water pump on if you are using the fresh water tank to supply water.
There is a water shutoff valve for the ice maker under the fridge. Remove the front panel below the fridge and you will see it there. It is most likely a push/pull type valve (don't confuse it with the 3 water heater bypass valves). From what you have said I'm guessing this valve is turned off.
Also check the ice maker water solenoid to be sure the wires are connected. (many times they are disconnected to winterize/de-winterize). That you will find behind the outside access door. there are 2 1/4" quick disconnect crimp connectors on it. It does not matter which goes where.
Let us know what you find.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 03-19-2018, 11:20 AM   #3
It is plugged into shore power in our RV barn and on city water. I'll try what you suggested and let you know. Thanks so much.
Santabobswife
Bob, Diane & Snoopy
Old 03-19-2018, 08:34 PM   #4
Thanks so much. It worked. You are a genius.
Santabobswife
Bob, Diane & Snoopy
Old 03-19-2018, 08:42 PM   #5
Valve was off?
2016 Honda Accord
Old 03-20-2018, 07:16 AM   #6
Valve was off?
Yes, it was off.
Santabobswife
Bob, Diane & Snoopy
Old 03-20-2018, 07:44 AM   #7
This should have been in the Sunseeker forum not the Surveyor
Sorry, I
posted in wrong place.
Santabobswife
Bob, Diane & Snoopy
Old 03-20-2018, 02:48 PM   #8
same thing happened in our forester 3051s, the so called techs at mike Thompsons couldn't figure it out. it works now and great at that
Philkaty is offline   Reply With Quote
Old 03-20-2018, 03:17 PM   #9
bikendan's Avatar
Sorry, I
Corrected
Equalizer WDH
Old 04-20-2018, 01:34 AM   #10
Haha this forum is the best just got our rv and our packing it up for a short trip tomorrow our first trip! Couldn't figure out why ice maker wasn't working....15 minutes on the forums boom answers the small push valve under the stove thanks so much for the posts and help!
Djtonton is offline   Reply With Quote
