Old 08-24-2012, 08:28 AM   #21
Herk7769's Avatar
I set my levels using the fridge as "zero" since it is the most critical component in "levelness" but fine tuned using the shower pan so it would always drain completely. My camper was pretty well built and with those two showing "level" the floor was also "level." I then set my pin box levels to that.
HAM CALLSIGN - KC3FFW
Old 08-24-2012, 08:31 AM   #22
Don't get carried away about being perfectly level. There is a good bit of tolerance built into your fridge. Most people just can't sleep if the bed isn't fairly level, so they obsess with getting it right. Also, your jacks are meant to stabilize your rig, not level it. Use common sense - a bit is OK, alot is not.
crasher is offline   Reply With Quote
Old 08-25-2012, 12:09 PM   #23
jriddering's Avatar
Well I found the best place for level is on the floor of the basement. With that level, the floor of the camper checks pretty good and the fridge checks good too. It is close the the landing gear too. The back bumper is off side to side so the basement is the way I am going.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
