Old 11-15-2014, 04:14 PM   #21
hockeytownmom's Avatar
Is this a standard thing? It wasn't mentioned in my walkthrough so I'm assuming I don't have it?
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 11-15-2014, 05:03 PM   #22
Average Joe
MrJoe's Avatar
It's an OPTION. Your thermostat will have Heat Pump written as a selection if you have it.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 11-15-2014, 05:10 PM   #23
Mike & Molly's Avatar
Use the furnace
If your camping in 30 degree weather - you are going to want the furnace operating. I haven't seen or heard of a heat pump that can keep your coach warm in that kind of weather. The best it can handle is a temperature down to about 45 degrees. Good luck.
Mike & Molly is offline   Reply With Quote
Old 11-15-2014, 05:15 PM   #24
mary ferguson's Avatar
He's right!! Mine wouldn't work and it's 38 here. Kept tripping breakers so propane it is!
mary ferguson is offline   Reply With Quote
Old 11-15-2014, 07:03 PM   #25
Jerry01's Avatar
If you are tripping circuit breakers, then you have other issues. We have the heat pump option in our RV as well. According to dometic, it works down to 30. We have only used it one time, since most of our camping is either dry camping, or warmer climates.I actually prefer the furnace since it is a little bit quieter. What circuit breakers are you tripping? Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 11-16-2014, 05:12 AM   #26
Note that while the heat pump may be an option for you, it does not provide heat to the water and sewer compartment like the furnace does. There are furnace heat ducts that run in the underbelly and heat ducts that blow on the water pump and sewer connections. If you use the heat pump or electric heaters inside, you lose the advantage of the heat ducts.
I find the heat pump to be a great option on those "cool" mornings when you need to take the chill out of the air. For serious winter camping, the furnace works best.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 11-16-2014, 07:51 AM   #27
trdutch's Avatar
I agree with RV Bill and the others that have talked about lack of heat in the water bay etc when using heat pump
If you want to take the chill out of the air use the Heat pump
Full furnace for winter camping and basement protection
Portable electric when shore power available for Free heat to save on Gas
But remember if it's really cold outside you need to be concerned with your plumbing getting heat so run that furnace, it's the cost of winter camping
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 11-16-2014, 07:51 AM   #28
Mikegjax's Avatar
On systems with the heat pump setting, the propane furnace should start automatically when the heat pump can't handle it any longer.
HEAT PUMP
mode, if the outside ambient temperature
is measured to be below 30F and the vehicle is equipped with a
furnace connected to the Comfort Control Center, the control will
automatically select the
FURNACE
operation and the
HEAT PUMP
will shut down.
Important:
If vehicle is not equipped with a furnace no heat
will be available below 30F. IF vehicle is equipped with a
furnace and it is connected to its own thermostat, it must be
manually turned ON and OFF for operation.
When this happens, the
AUX. HEAT
and the
HEAT
PUMP
indicators
on the LCD will illuminate. Once the outside ambient temperature is
measured above 38F, the control will return to the
HEAT PUMP
operation and shut down the furnace if it is connected to the Comfort
Control Center. If furnace is not connected to the Comfort Control
Center, the furnace thermostat must be manually turned off.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-16-2014, 10:27 AM   #29
Average Joe
MrJoe's Avatar
Mine doesn't switch from heat pump to furnace automatically, it's a manual function.
Joe and Karen
Old 11-16-2014, 10:47 AM   #30
Mikegjax's Avatar
I am going to check it out for sure when we get our first freeze. Might be this week. Will post my findings as soon as get them.
2014 Solera 24R
USN Retired
