11-13-2014, 07:01 PM
Inside Heat
Is the inside heat operated on electric when plugged in or does it always operate on propane? We have a Sunseeker 2014 and LOVE IT!
11-13-2014, 07:36 PM
Carknocker Family
Mine is always propane. 12 volt so it doesn't have to plugged it to work. Most people by a electric heater and use it to heat camper. Its free heat when at a campground and save your propane.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
11-13-2014, 07:37 PM
Perfect! Thanks for the advice!
11-13-2014, 07:48 PM
Carknocker Family
Just check the amp rating on the heater you buy, too big and it will pop your camper breakers. Especially if you use something on the same circuit.
You could run an extension cord from the 20 amp pedestal plug to the electric heater. Just throwing out info for ya.
We enjoy winter camping around here!
2017 Ram 2500
2014 Salem 32BHDS
11-13-2014, 07:51 PM
👍👍👍 that we will do! We love camping all year round but this time of the year I think is just best too!
11-13-2014, 08:29 PM
Average Joe
We have the heat pump option on our Sunseeker. It works only when plugged in or when the generator is running. We also have the propane furnace that can be used without being hooked up.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
11-13-2014, 08:31 PM
Oh great! That's probably our option as well since we have a 2014. Thanks!!
11-14-2014, 05:11 PM
Check your thermostat to make sure. The very last setting on the left of it would say heat pump. If it does not you do not have the heat pump option.
11-14-2014, 05:17 PM
Will do!! We just took it to Oklahoma and will check it out after our big winnings! Hopefully!!
11-14-2014, 05:55 PM
The heat pump comes with the 15k btu ac unit
11-14-2014, 06:05 PM
I turned our heat pump on last night but it got below freezing and I learned from the Solera thread that at about 30 degrees the heat pump doesn't work. We have the 15k btu ac and I'm now curious if the furnace automatically kicks on when you have the thermostat in the heat pump position? MrJoe also commented on that thread but I'm still unclear if how to leave the thermostat setting?
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
11-14-2014, 06:13 PM
The heat pumps today work down to
Freezing. Changing from heat pump to furnace is a manual action not auto
11-14-2014, 07:01 PM
Ok great! We have the Heat Pump option on out Sunseeker so it will be good to run in freezing weather or should we use the furnace?
11-14-2014, 07:11 PM
Give it a try to see how it works based on the outdoor temps. I left my camper overnight when it got down to freezing. With the thermostat set at 62 it was comfortable the next morning.
11-14-2014, 07:25 PM
Just found out that none of our electrical plugs work.. Yes we r so newbies and need help! Lol
11-14-2014, 07:27 PM
Are plugged into shore power? Are your lights working
11-14-2014, 07:30 PM
I use an electric heater.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
11-14-2014, 07:36 PM
So set the furnace thermostat to come on when the heat pump goes off. If necessary use 2 separate thermostats.
11-14-2014, 08:53 PM
What is a heat pump?
Kristina
2021 F150 XLT
Previously:
11-14-2014, 09:07 PM
Average Joe
Inside Heat
A heat pump is an air conditioner with the ability to run backwards, basically. With the heat pump option, my air conditioner produces heat instead of cooling when heat pump is manually selected on the thermostat. It will blow warm air from the ceiling outlets. It will not provide heat to the basement area nor will it work below ~32 degrees.
Joe and Karen
