Old 01-14-2016, 07:22 PM   #1
inverter
My inverter on my 2002 sunseeker 2900 is shot. However the battery cable has been broken for over a year. Does the rear battery still get charged somehow? Do I need this inverter for anything? I have a generator to run ac power if needed. Any suggestions to charge the back battery? Thanks Rudy
baldrudy is offline   Reply With Quote
Old 01-14-2016, 07:32 PM   #2
BendOrLarry's Avatar
I don't know how you have things wired, but the inverter doesn't charge the batteries unless it's an inverter/charger. You probably have a converter which is what charges your batteries.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 01-14-2016, 07:46 PM   #3
I wont be able to get more info on the inverter or converter or whatever it is until this weekend. It has 2 cables that go to the battery on one side and a romex wire that comes out the other side and goes into a box that I think is a transfer switch.
Old 01-14-2016, 10:09 PM   #4
sgtlm17's Avatar
Converter charges your batteries and is typically in a brown covered box with your fuses and breakers. Inverter converts your 12v battery supply into 110 and typically an aftermarket install
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 01-14-2016, 11:08 PM   #5
A32Deuce's Avatar
Is that located in the last compartment on the pass side? If so , it is the converter for charging your bats. Should be hard wired into the panel were circuit brakers and fuses are. I had to change mine.
A32Deuce is offline   Reply With Quote
inverter
