Old 06-21-2018, 07:08 PM   #1
Irritating Squeak
Does anyone have a suggesting on how to manage / repair a squeak that is coming from the RV door as we are driving. To me it sounds like a metal on metal rub from the door latch or lock. As we are going to be traveling for 6 weeks in the fall it would sure be nice to eliminate the sound.
We have a FR Sunseeker 2500TS.
Keran
Kmaclac is offline   Reply With Quote
Old 06-22-2018, 06:38 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. Try putting some lube on the latch and striker plate and see what happens, you can also try thin weather seal around the door lip
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-22-2018, 08:44 AM   #3
RedLdr1's Avatar
Welcome to the forum. We pick up our new 2500TSF Tuesday.
Open the door and look carefully at your door frame and see if the door is rubbing the paint. If it is you might be able to shim the door, to re-square it, to help cure the noise.
Also use a good rubber preservative, like 303 (See Here), on the door seals. That can help as well.
As SeaDog suggested some thin rubber seal may also cure your squeak. I would add it to the door, instead of the frame, so it is out of sight if I went this route...
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is online now   Reply With Quote
Old 06-22-2018, 08:51 AM   #4
Keran
My DH put weather seal around the door frame.
lacrawgator is offline   Reply With Quote
Old 06-22-2018, 05:42 PM   #5
Total Loss's Avatar
I stuff a piece of foam between the screen door and the door. Helps a little. I also lock the dead bolt- tightens the door up.
Some folks just throw a large pillow in the footwell and jam it up against the screen.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 06-22-2018, 07:41 PM   #6
We put a piece of folded up paper towel between the screen door and the inside frame.
jst3 is offline   Reply With Quote
Old 06-22-2018, 08:15 PM   #7
Duckogram's Avatar
I thought that was my DW so I turned my Miracle Ear off.
ILB ( | )
Old 06-23-2018, 07:52 AM   #8
Thank you all for the great suggestions. Once I give it a try I will report back on how they work.
Keran
Old 06-24-2018, 01:50 AM   #9
Kirk S's Avatar
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
