Old 07-02-2013, 02:51 PM   #11
wplate's Avatar
Originally Posted by Geri View Post
If you find a good routing, please post. We're running a ham hf radio in our 2690SF and have been mounting a hustler on top of the ladder and running the coax across the roof and in the window. But that only works when we're parked.
Here's what we did:
We drilled a 7/8" hole just to the right of the left awning support into the outside kitchen area. Having the router in the kitchen area behind the TV was easy to access. We drilled a larger hole in the left side of the cabinet to get the power strip lead out. Then we got a splitter for the AC power the fridge uses.
We put 1/2" PVC through the hole in the RV wall. On the exterior side we cemented on a 90ļ elbow with the other end threaded. This allows us to screw the pipe "closed" when not in use. On the interior side we attached a 1/2" PVC coupler but didn't cement it, it is just helping hold the pipe in place. Finally we put Dicor around the outside of the pipe to seal around the PVC.
For now I am keeping the external antenna "temporary" and will take it down for transit. If that becomes too annoying I may look at a way to secure the cable up along the inner edge of the awning support.
Photos attached.
ID:	34452   Click image for larger version
ID:	34453   Click image for larger version
2013 Sunseeker 2860DS
2014 Jeep Wrangler Unlimited
wplate is offline   Reply With Quote
Old 07-02-2013, 03:36 PM   #12
VinceU's Avatar
Originally Posted by wplate
Here's what we did:
Photos attached.
Nice job! You can always use a threaded stuffing tube IWO of your plug and thus seal the cable penetration.
