Old 06-02-2018, 02:30 PM   #1
dcheatwood's Avatar
Is second A/C on the way
I went to look at a new 2018 Sun Seeker 3010DS yesterday at a local dealership. Plugged in 30amp and started the 15000 (18000) BTU ac while we were there. 95 degrees outside. Could not feel it cool down any during the half hour we sat in it. Very little air coming out of most vents. The GM had been bragging on the Atwood super fancy 15000 BTU a/c that put out like an 18000 btu. Says even with 2 a/cs it takes 2 hours to cool down an RV. I know better because my 5er can chill you out in 30 minutes with both a/cs on in the hottest months. Now he tells me he has some 2019 models ordered that will have 13,500 btu amd 11000 btu a/c but still 30 amp.
Have any of you heard this, or can anyone here comfirm?
In Louisiana, like most southern states, 2 air conditions are necessary to maintain comfort May through Oct.
2018 Forester 3011 DS
Old 06-02-2018, 03:00 PM   #2
Duckogram's Avatar
I have the AirCommand and it’s just as hot and humid here in S Florida. I cranked the genset up to power my air compressor and hit the A/C to put a load on the genny. Proceeded to air up the tires and put the sims back on. When I was finished, about 45 minutes later, the unit was at 76* with the stat set on 74*. Something was wrong with the unit on the lot. Maybe the door was open, shades up, burners on and vent fan running. Maybe your sales person was putting out too much hot air.
One 15k will cool a 30’ box adequately. It’s all about managing the heat penetration.
As for the dual A/C’s on a 30 amp coach, have not seen that yet.
ILB ( | )
Old 06-02-2018, 03:45 PM   #3
Citrus County, Fl.
GL1800Rider's Avatar
The only Class C that offers 2 AC units without getting into a super C is the SOB Thor Jayco Greyhawk Prestige but I am to loyal to FR. If Forester/Sunseeker offered that I might be tempted to trade.
I have heard the Atwood does a great job of cooling but the heat pump is a little quirky with its constant air sampling.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 06-02-2018, 05:32 PM   #4
dcheatwood's Avatar
I have to think the AC was not functioning correctly. I'll post back when (if) general manager gets a dual AC class c.
Old 06-06-2018, 04:50 PM   #5
dcheatwood's Avatar
Ok. Forest River rep says yes, they are working on adding 2nd a/c to next year's Forester. They will likely be 13,500 and 11,000 btu, still on 30 amp circuit and still with 4000 Onan Gen.
Old 06-06-2018, 05:30 PM   #6
I can't imagine running 2 AC's on a 30 amp circuit. (Well, maybe running, but not starting.) I'll have to see to believe it. MAYBE if they've both got Micro Air Easy Starts on them.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-06-2018, 05:46 PM   #7
Oaklevel's Avatar
X 2
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 06-07-2018, 09:11 PM   #8
dcheatwood's Avatar
Another question. I see the outside speakers are in the awning arms? How are they?
Old 06-07-2018, 09:48 PM   #9
Duckogram's Avatar
Good for not having holes in the side of the RV. Bad for your neighbor unless your awning is tilted full down on both sides. I really like how the Solera operates though. Very well engineered.
ILB ( | )
Old 06-08-2018, 04:46 AM   #10
dcheatwood's Avatar
Yeah, I was thinking the speakers were directed away from where you sit under the awning. Little things i know but just curious.
