Old 08-29-2016, 10:40 AM   #1
Is there a better tire available for large Class C's ?
For those that get Motorhome Magazine, there was a featured question in the Coach and Powertrain section regarding trying to put a better (stronger, longer lasting) tire than the Michelin LT225/75R16 on a Class C motorhome. The answer given was just the normal: keep them inflated, covered, check the date code, etc.
I sent Ken Freund the following e-mail:
Ken Freund,
Good answer to the highlighted Tire Failure question in the September 2106
Coach and Powertrain.
However, you did not answer the main question that he asked that I would also
like to ask. "Is there a better, stronger tire in the LT 225/75 R16 size that what
Michelin makes"?
Personally, I believe that the heavier, larger class C rigs stretch these tires
to the absolute limit which leads to premature tire failure. Is there a better, stronger
tire in that size available other than the Michelin ?
Thanks.
Haven't heard back from him, but maybe someone on this forum has some input. I'm not looking to change rims, tire size, etc., just curious if there is a better tire in that size?
ActionJackson is offline   Reply With Quote
Old 08-29-2016, 11:55 AM   #2
ilmor's Avatar
I also have a Sunseeker with the same tires, so I'm curious why you're asking. Are you experiencing any unusual wear or have you had other issues?
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-29-2016, 12:18 PM   #3
With my last rig, a 29 Coachman w/o slides, I did experience tire failure at about year 5 of the tires. Right on the edge of when they recommend to replace. Now I have a much heavier 3100SS Sunseeker and want to try to avoid a repeat.
My issue is that the tires are run so close to their maximum capacity. Example: My passenger car has tires with capacity of 5,732 lbs. Car weighs 3,500 lb. Tires are carrying only 61% of their capacity. My RV tires have a capacity of 15,240 lbs. and RV is close to it's capacity of 14,500 lbs. Tires are carrying 95% of their capacity. That's cutting it close.
My friend had Michelin tires on his car for 17 years and they didn't fail. He drove the car (show car ) very rarely ( like a motorhome) and kept the tires covered (like a motorhome should). I just feel as though if a person uses his motorhome frequently and maintains the tires, they should not have to be changed every 5 years. This a Florida MH that gets used year round. Maybe if there was a stronger, more durable tire available, they would last longer.
Old 08-29-2016, 03:39 PM   #4
One possibility would be to put commercial tires such as the delivery services use. I considered putting Bridgestone Duravis on our Four Winds, but I caved for the Michelin LTX M/S. As it worked out, they were replaced with LTX M/S2 under the recall a few years ago after I'd already put 25K on them, so we scored on a new set which reset the date code. The M/S2 are much better tires than the M/S ones were in the terms of noise, handling and stability. I still wonder if it would have been a better decision to install the Bridgestones.
I see Costco has the Duravis M700 HD's with closed shoulders but an open tread; they used to have a Duravis with a much tigher highway tread that I was considering.
That all said, they all have a load range for a given size, so it doesn't really matter what brand or model you buy. If it's an LT 225/75/16, then the load index is 115.
I still like the idea of a commercial tire... and may purchase something like that when I replace the Generals on the new Sunseeker when the time comes.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 08-29-2016, 09:37 PM   #5
3071DS
Garrette's Avatar
Following as I want to know also.
Garrette is offline   Reply With Quote
Old 08-29-2016, 11:53 PM   #6
Your question reminds me of a problem I had back in the 70's with a truck camper and radial tires. When driving on a freeway, she would wander back and forth just a little, but enough for us to notice. I search everywhere I could (remember no internet in those days). Everything checked out okay on the truck. Finally, I stopped in a large tire store serving only 18 wheeler rigs and large trucks. They recommend that I change the rear tires from radial to "bias ply" tires which had a stiffer side wall than radials had. You know, they were right, and I had no movement for the rest of that camper's life.
Now, to extend my experience on tire questions some 40+ years later, I would suggest finding a really good truck tire store that only services trucks, large trucks. Ask them what they would recommend and see if you can get a good answer from them. They are the professionals and should be able to help.
And, don't forget to let all of us know if you find something out.
Wayne Lee
Out West Somewhere
2016 Sunseeker 3050DS towing 2006 Hummer H3
WayneLee is offline   Reply With Quote
Old 08-30-2016, 12:40 AM   #7
Witch Doctor's Avatar
I have the Michelin LTX/MS2 on my truck, I don't think I could find a better tire.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-30-2016, 04:41 AM   #8
ilmor's Avatar
I assume you have the LTX MS2 like I do? According to Tire Rack they are rated for 2680 lbs each x 6 = 16,080 lbs. which would be 90% of capacity in your case.
Capacity means just that plus there's also always a safety factor built in. If you had a tire fail, that happens sometimes and could happen with any tire. Thousands of motorhomes use them w/out failure.
I also believe that no matter what tire you buy they have a life of 6 years (you say 5, I've always read 6). This is due to rubber aging, not capacity. This would be true even on your car. I just replaced a perfect-appearing set of tires on my car that were 7 years old (i was getting nervous).
Now having blabbed out my thoughts I do understand your concern and what you're thinking, however I believe that you'd be better off saving your money or spending it on something else.
Old 08-30-2016, 05:54 AM   #9
DW's Retirement Plan
DaGrinch's Avatar
Ditto
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 08-30-2016, 09:16 AM   #10
Total Loss's Avatar
My bud swears by the Bridgestones. Never a leak or issue.
I will look into them after the 5 year mark.
I am under loaded on my small rig but tires are of utmost importance.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
class c, tire
