09-29-2018, 10:02 PM
Is there a good reason....
or am I just cynical. The only power for the bedroom TV in our 3170DS is a 12v outlet. Why not a standard plug? Did they save $.27 by doing it this way?
Anyway, how did you resolve this, with a converter or install a 120v outlet? If you put in an outlet, where did you run the line from?
Thanks,
John
"If I was any better, I'd be dead!"
"The sun's always shining, otherwise it would be dark!"
"God looks out for the stupid, so I keep Him pretty busy!"
2012 Forest River Sunseeker 3170 DS 32' w/2 slides
09-29-2018, 10:39 PM
Certified Curmudgeon
Thanks,
John
I don’t have a 120v TV anywhere and I’m fine with that. FR puts in what sells.
I take it that you don’t dry camp where you can’t run your generator. It’s nice to be able to get the news/weather every once in a while on a 12v set. Going outside during a dark sky is better than any TV show anyway.
To answer your Q, I resolved the issue you stated by correctly assessing the importance of a TV while touring America the Beautiful. I’m in Sunset, TX tonight and no TV. Ahhhhh.
Obviously, YMMV
Mike Dropped
09-29-2018, 11:16 PM
Retired and Loving Life!
I have four in my 3171DS and they are all that way. I don’t mind, until I have to replace one of them and have to look for a 12v tv.
09-29-2018, 11:29 PM
Thanks,
John
I removed my 120v 24” Furion TV and replaced it with a 12v 19” Samsung and wired in a special 12v outlet for it! I can use it when I dry camp and if I am plugged in to shore power, the 12v power comes from the converter (via the batteries). Perfect for us!
Campah
2017 Rockwood 2109s Mini Lite
09-30-2018, 12:35 AM
Thanks,
John
Might be easier to buy a 12v to 110v converter and get your 110 from there.
Coachmen M/H
Concord
2018 / 300 DSC
09-30-2018, 06:38 AM
Well, nomad297, I ARE a college graduate! Being a former engineer I was just looking for some sense to their logic of a 12 v and not a 120 v. And no, we don't dry camp or boondock and use the generator....although now the option is available. Actually, according to my bride, we don't even camp. She says we're "glampers"...WIFI, cable, AC, etc. People camp how they want to camp.
ANYWAY, I will order a converter and move on.
Thanks!
09-30-2018, 06:50 AM
I’ll try to answer your question without being confrontational, what I did was Download the App for Directtvnow, I get 65 channels on my iPad or iPhone for $35.00 A MONTH. It’s Data Free Streaming if your already a ATT WIRELESS CUSTOMER. If not it will use your Data from your phone plan to stream with can be Huge unless you have unlimited data. I also understand there are ways to mirror it to your TV.
09-30-2018, 06:51 AM
From reading a lot of posts, although I do not have one, Sunseekers just seem to have 12 volt TVs while most of the other FR MHs use 120 volts. Have never figured that out. Maybe whoever designed the electrical layout was trying to help occasional boondockers watch tv without running generator or installing an inverter. Always seemed strange to me as well.
2015 335DS
09-30-2018, 07:11 AM
I suspect, it’s because you have an either or option. I’d see this as a plus. The TV will always work if you want it, whether you have 120v available, or not.
09-30-2018, 07:29 AM
Thanks!
You’ve got that right, about how people camp! Here’s a nice, inexpensive and compact inverter with great reviews on Amazon:
https://www.amazon.com/Foval-Power-I...70_&dpSrc=srch
Bruce
09-30-2018, 07:39 AM
27¢ x 100 trailers = $27.00 in profit. Yep, it was a economic decision.
Until this morning I never realized there were 12vDC televisions. Personally never had nor wanted nor would SHMBO allow a TV on board but a 12v version makes sense and certainly lets it be used under all camping conditions. I just Googled 12v TVs and they're common as grass!
-- Chuck
09-30-2018, 07:54 AM
-- Chuck
Well, actually all modern flat panel TVs are DC operated anyway.
$0.27 strikes me as a a little low for an additional outlet and would even cover the box and plate. Maybe $5 to $10 might be more reasonable with all parts and labor.
2015 335DS
09-30-2018, 08:22 AM
[QUOTE
$0.27 strikes me as a a little low for an additional outlet and would even cover the box and plate. Maybe $5 to $10 might be more reasonable with all parts and labor.[/QUOTE]
Actually, I made up that number, I have no idea what the difference in cost would be ...... remember that "47% of all statistics are made up on the spot". And Chuck S is right, even at mere pennies, the profits add up!
And, like Chuck S, I also never realized the plethora of 12 v tv's out there. For me it was simply more cost effective to buy an inverter very similar to the one nomad297 suggested. Especially since we already have 16! tv's. (yeah it seems excessive but - 3 from the traded in trailer, 3 came in the motorhome, and 2 furnished houses - holy smokes it adds up).
09-30-2018, 08:27 AM
Thanks!
Not really understanding why you need an inverter (which is the correct term) for this.
Your TV will run off 12 volts. so you can use it off of only battery power if you wanted/needed to.
If you are connected to 120 volt AC shore power, then your RV's converter will take 120 volt AC and convert it to 12 volt DC and power the outlet to the tv anyway. So you are good either way you go. Don't see why you need to get anything, unless you change the television itself.
This thread may help, as it explains the different electrical systems you have in the RV... as well as the difference between a converter and an inverter.
http://www.forestriverforums.com/for...nt-152813.html
Are you perhaps having a problem with the 12 volt outlet, and your television isn't being powered currently?
2011 Flagstaff 831 RLBSS
09-30-2018, 08:36 AM
Hey Duckogram, tried to send you a pm but it wouldn't send...
09-30-2018, 08:37 AM
Trailer Park Supervisor
Was at BJ's wholesale the other day, looking at the TVs on display. Most of them I would consider 'RV size' are 12 volt, running off of an AC to DC transformer in the cord. At Hershey RV show, I saw RV's with TV's that would rival my large screen in my home, amazing. I guess those people really aren't into camping, just dragging a home around, lol.
Yes, I drink the water!
09-30-2018, 08:43 AM
No, the problem is, the tv is 120 v and there is no place to plug it in in its present location. So, I need an (correctly ) inverter to even have power to the tv.
09-30-2018, 08:45 AM
Converting 12vDC to 120vAC and then back to 12vDC ain't making sense to me.
I recall a couple of my home TVs have black box power supplies between the wall and the TV. Without moving major furniture I can't tell if their output is 12vDC or similar but if it is it's a simple matter of buying or fabricating the appropriate power cord and plugging directly into 12vDC in the RV.
-- Chuck
09-30-2018, 08:46 AM
geezer with gadgets
Inverter
We use a small inverter and it works fine.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
09-30-2018, 08:49 AM
Yup, we've been that route with cable/directtv/etc. and we cut the cord a while back. All we have now is OTA, sling, hulu, and netflix. I don't watch much tv but my bride likes to watch tv when she goes to bed at night.
Thanks, though.
