Old 05-15-2018, 09:36 PM   #11
Duckogram's Avatar
I made one. Easy peasy. See my post under 2800QS mods.
ILB
Old 06-14-2018, 07:16 PM   #12
Professional Tinkerer
RV-Duff's Avatar
I had a similar issue on my 3270. When I pulled the cover off the bed and could see the tank, I found that they had secured the midpoint of the hose ABOVE the inlet height. So, water had to be forced uphill until it was past the midpoint before it would drain down into the tank. I remounted the hose midpoint support to a lower level that put the hose at a constant slope to the tank and I no longer had an issue.
2018 Sunseeker 3270...
...sleeps 4 (2 adults, 2 kitties)
RV-Duff is offline   Reply With Quote
Old 06-28-2018, 11:37 AM   #13
Sag in the hose
There is not much difference, about 2" from my guesstimate, between where it fills and the tank entry. Did not seem to matter the speed of the water, some wanted to run backward. Indeed at the factory, they zip tied the midpoint higher than the entry point. I have made the slope better to the mid point, and moved the hose midpoint support by adding a board. I think it will be better but I'm not sure yet.
Flippin
2018 Sunseeker DS
FlippinUid is offline   Reply With Quote
Old 06-28-2018, 11:50 AM   #14
Water fill
Well I have a 3051s and I found a fill adapter to fill it with no problems. The fill adapter is no longer being sold. You could make one. Secure-Fill SNL1SF RV Fresh Water Fill
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
fresh water, tank, water, water tank
