Originally Posted by rgarner
I have a 2004 Sunseeker 3100 Class C. After having some issues with the valve extenders and the local tire shop, I I have decided to deal with this myself. I have a 20 ton Bottle jack.... and I want to make sure I put it in the proper place Before trying to jack up the rig to deal with the tires . Any advice and information will be most appreciated.
Doesn't the chassis mfg. show jack points? You should really use stands once the wheel clears the ground, maybe you intended to, without saying so. On a vehicle that large you should find plenty of jack points, flat and heavy areas, its not nearly that much load on each corner.
