Old 07-16-2014, 07:31 AM   #11
Instead of running 12 volts from the battery you may have a spare fuse in the power distribution panel. It will be closer and you would already have a fuse. Would be a neater job.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 07-16-2014, 07:31 AM   #12
GM
bclemens's Avatar
Let me rephrase that. It would not pass a 5,000lbs pull test as it was built back then.
Yes, we did find a way to add the seat belts back there, but that required us adding backer and more framing inside of the slide floor. Just bolting through the slide floor was not going to pass.
Personally, seat belts in the living area of RV's to me are just the "politically correct" thing to do. Frankly rear facing seat belts, side seat belts etc I think are just to make some people seem safer. Back in the day we would all ride in the back of trucks, ride in the truck camper laying in the overhead bunk looking out the windows (front and side), we never had seat belts.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-16-2014, 07:35 AM   #13
DMezzoprete's Avatar
Thank you all for your help! I'm not great as an electrician so I'm just going to take it to a dealer and have them install a 12V outlet.
DMezzoprete is offline   Reply With Quote
3170, sunseeker
