Old 06-26-2015, 05:26 AM   #11
Checked the fuse and it was just fine. Need to explore in the storage area under the slide. We just discovered the light in the storage area under this area is not working either.
Shellypatti is offline   Reply With Quote
Old 06-26-2015, 06:24 AM   #12
Ddubya's Avatar
Had a similar issue with lighting in the kitchen area. I called Prime Time and was told that the 12v lights that were out were wired in series. I found a crimp connector hidden in the cavity behind a light that was not properly installed. The connector had turned black from the heat caused by the loose connection. Replaced the connector and all is good.
Ddubya is online now   Reply With Quote
bed, bedroom slide, roo, slide
