Had a similar issue with lighting in the kitchen area. I called Prime Time and was told that the 12v lights that were out were wired in series. I found a crimp connector hidden in the cavity behind a light that was not properly installed. The connector had turned black from the heat caused by the loose connection. Replaced the connector and all is good.
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
