09-02-2015, 03:45 PM
Leak Behind Toilet
When adding more than normal water to my toilet (via city water) to get a good dump, I noticed water running across the floor from under the boxed-in plumbing behind the toilet. Then I found water in the storage bay. I am assuming it’s a fitting or hose near the toilet and simply migrated to the storage area which is lower.
Does anyone know the easiest way to remove this boxed in frame? And once removed, can I simply pull the excess pex hose up and repair it? Otherwise, I’m not sure how to get to it and don’t want to go to the dealer. (not good service reputation). I’m not the most mechanically inclined person (seriously lol), but I assume it’s an easy fix if I can get to it.
Other ideas welcome.
2016 Forest River Sunseeker 3100SS
09-02-2015, 05:58 PM
The box is fairly simple to remove. First pry up the edging or molding, around the box, with a putty knife or flatbar. Typically they use a staple to attach. Then do the same for the panels. The pex lines will have a little flex. Usually they use crimp fittings on the pex. I've replaced fitting in my first trailer with the 1/2" shark bite fitting that you find a Home Depot. Good luck.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
09-02-2015, 09:15 PM
Thanks for the reply. I removed the toilet and bottom portion of the box. The top is screwed in from the opposite side of the wall and I darn near broke it. Well, I did break part of it but it re-assembled fine LOL. I re-installed the toilet and flushed using the pump. I could not detect any new water leaking and I could see most, but not all of the connections above the floor.
Maybe this is a city water issue coming from another line? It's late and I set the project aside for now without trying the hose. When it leaked, I was on city water using a pressure regulator. I was flushing for quite some time to add water to the black tank. Might be why the issue showed itself. Any other time on FHU we simply flushed which is fairly quick
The up side is that I don't always use city water. The down side is that I still don't know (for sure) why I had the leak. More digging to come but thankfully camping is not held up. Praying the problem does not show up on the road though.
Thanks again.
09-02-2015, 09:30 PM
I've had to replace the flush ball valve where the water intake is on the foot petal. First sign of failure was a mystery wet spot on that side of toilet. Had water coming out the door of the bathroom (just a small bit). Dried it up and didn't leak again for a month or more. Leak finally got consistent enough for me to see it was dripping from the foot flush valve.
Keep an eye on it, might be the culprit.
2011 Sunseeker 3170DS - 30,000 miles explored
04-04-2016, 09:09 AM
Well... after taking the bathroom apart last year and never finding my leak..... the leak miraculously disappeared. I was pleased, baffled and knew things like that don't just go away.
Toward the end of a 2 week trip this year the leak returned. Hearing an "air" sound at the city water inlet I thought I found the culprit. Pulled off the inlet, hooked up water and yep... a leak.
Easy fix and a new (better) city inlet is on order. I have always tried to lessen the stress on that inlet because I knew the hose weight was a lot. I'll chalk it up to a weak part.
Even though the water showed up away from the inlet I should have ruled out the easy answer first. Lesson learned.
04-04-2016, 11:10 AM
Are you using a water pressure regulator in your city water line? If not, that might explain why seemingly normal connections might leak.
Camco 40055 Brass Water Pressure Regulator https://www.amazon.com/dp/B003BZD08U..._RhPaxbVWZ4VRB
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
04-04-2016, 11:27 AM
Yep, I always use a pressure reg. The unit had 9000 miles when I bought it a few years ago so I don't know what others might have done. I suppose they could have left the water hose on during a freeze as well. However, the factory plastic inlet can be easily strained by a hose and I will be more confident in the stronger one.
We're happy campers though. We love our Forest River Sunseeker.
04-04-2016, 01:24 PM
Always Learning
I've always used a pressure regulator and still find that my camper (Sabre fifth wheel) has little leaks crop up here and there. I think it's just part of travel.
04-05-2016, 02:21 PM
We use a 90 degree elbow on the city connection , helps w/ the hose weight.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
