Old 10-19-2014, 10:59 AM   #1
Leak from black tank pipes into compartment
We have noticed a small leak in the pvc from the black tank exit and the dump valve. It may be leaking at a seam. Will be on the road another 6 days before we can get it checked. Is there cause for concern?
Hodie Ho is offline   Reply With Quote
Old 10-19-2014, 11:31 AM   #2
Ford Idaho's Avatar
I would take extra measures to clean the tank out before hitting the road and run with it empty and then perhaps a wrap or three of duct tape to hold it in place.
A small pail or other container under it when parked to prevent ground contamination as a good idea.
Old 10-19-2014, 12:44 PM   #3
That's what ee've been doing ex except for the duct tape. Will give that a try when we stop today. Thanks!
Old 10-19-2014, 12:45 PM   #4
That's what we've been doing ex except for the duct tape. Will give that a try when we stop today. Thanks bunches!
Old 10-19-2014, 12:46 PM   #5
That's what we've been doing except for the duct tape. Will give that a try when we stop today. Thanks bunches!
Old 10-19-2014, 07:07 PM   #6
Sunseeker waste valves are inside a heated compartment so it won't leak on the ground.
ATVer is offline   Reply With Quote
Old 10-20-2014, 09:58 AM   #7
Does anyone have any idea as to why it would start leaking all of a sudden. We have been using it monthly since May 2013 with no issues. Seems to be where 2 pieces of pvc are glued together.
Old 10-20-2014, 10:37 AM   #8
Likely just a poor glue joint and vibration and temperature cycles have caused it too fail.
Old 10-20-2014, 02:35 PM   #9
Sunseeker waste will leak on the ground when the compartment overflows!
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 10-20-2014, 03:18 PM   #10
Check the bolts THAT HOLD THE DUMP VALVE TO THE PIPE, MINE WERE LOOSE AND IT WAS DRIPPING FROM THERE, TIGHTENED THEM UP AND THAT FIXED THE PROBLEM,
Kevin & Judy is offline   Reply With Quote
black, black tank, leak, tank
