04-15-2015, 11:21 AM
leak in fresh water tank
We have a small leak on the top of the fresh water tank. Is there some kind of sealant that would be safe to use?
In filling the fresh water tank, we have used a funnel. Is there something that can be attached to the fresh water hose to hold it in place?
04-15-2015, 11:38 AM
Canadian Member
Not sure about the sealant. How did you determine you have a leak in the top of the tank? Do you have a picture you can post?
For filling the FW tank, you can use one of these to connect to a supply hose.
Camco 40003-X RV Water Tank Filler with Shutoff Valve: Amazon.ca: Automotive
If you are filling from a jug, and money is no object, you can rig up a 12V water pump.
04-15-2015, 11:41 AM
I always found filling the tank thru the gravity connection was a messy PIA. I installed a valve and line between the outlet side of the water filter and the fresh water tank drain line between the drain valve and the tank. In my unit I needed two Tees, a valve and about 12" of pipe and is accessed thru the door for the water filter. It allows for pressure filling of the tank via the city water connection. Another simpler modification would be to put a female hose connection on the end of the tank drain. Then you could put you fresh water hose there and pressure fill the tank thru the drain line.
04-15-2015, 11:42 AM
Originally Posted by ATVer
I always found filling the tank thru the gravity connection was a messy PIA. I installed a valve and 18" line between the outlet of the water filter and the fresh water tank drain line between the drain valve and the tank. It allows for pressure filling of the tank via the city water connection. Another simpler modification would be to put a female hose connection on the end of the tank drain. Then you could put you fresh water hose there and pressure fill the tank thru the drain line.
So do you "un-cap" the gravity fill before doing so?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
04-15-2015, 11:56 AM
TURBS
You can take the cap off but you don't have too since the tank is vented thru another line which exits thru a screened vent next to the cap.
04-15-2015, 12:14 PM
In my experience you can literally fill the tank "faster" with water then air can escape from that air vent.
And that be bad.
Which is why I was asking
TURBS
04-15-2015, 12:33 PM
And that be bad.
TURBS
Yes ,filling that way is (Faster) and you can even get more (Capacity) UNTIL the FWTank becomes a (Water Balloon) and lets Go! Pressure filling a Gravity fill Tank is a Very Bad idea! Youroo!!
04-15-2015, 12:50 PM
Lets do some Math here,5/8 garden hose at 40PSI IN! Out is 3/8 vent tube at 40PSI! OLD Faithful!! Youroo!!
04-15-2015, 02:24 PM
And that be bad.
TURBS
Don't know about Trailers but the Sunseeker vents are at least 1/2", the same size as the PEX water supply lines so venting rate is not an issue. However one can still leave the cap off to be sure.
