Old 07-09-2014, 04:54 PM   #11
Ford Idaho's Avatar
Olive oil.
Food grade.
Plant based.
Old 07-09-2014, 05:03 PM   #12
I use silicone grease that you can pickup in the plumbing department of any home center on my whole house filter O-ring each time I replace it. It doesn't damage the rubber and is what it was designed for. I also use it for the O-rings in my sprinkler system compression fittings when I reinstall the backflow preventer each spring.
keith_h is offline   Reply With Quote
Old 07-09-2014, 05:41 PM   #13
PPST OGCDG
Frank-VA's Avatar
I have done the same when changing the water filter. I also do not put antifreeze in the filter housing no more. (W@(M@^T Brand) messed up my
filter housing. One on the left is new, one on the right is the one that the antifreeze messed up. I installed a By Pass Kit on out filter system. Quick Turn By-Pass Kit - Camco 35983 - Winterizing - Camping World
WaterPur Filters
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 08-15-2014, 09:25 AM   #14
Hoglou's Avatar
Love to see pics of the bypass installed.
Hoglou westGA
KM4HQQ 146.640mhz
Old 08-15-2014, 05:59 PM   #15
Hoglou's Avatar
The seal is available at Lowes....
Hoglou westGA
KM4HQQ 146.640mhz
leak, water, water filter
