Old 01-13-2016, 09:56 PM   #1
Leaky compartment behind genset
Every time we drive in the rain, I get water into the compartment that is behind the genset. Has anyone else had the same thing happen? I tried to seal the plastic tub around its top seam. Now I think it might be coming in behind the big blob of gray spray foam insulation where the genset conduit comes into the compartment.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 01-18-2016, 04:22 PM   #2
Hoglou's Avatar
I have not had the leak but I have replaced some of the foam on the coach. I would pull the old foam out and reseal. I used great stuff pest proof formula from Home Dep. It will match color and wont get chewed.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 01-18-2016, 09:42 PM   #3
Lou, what prompted you to do that?
Old 01-19-2016, 08:34 AM   #4
trdutch's Avatar
2860 DS
I had dampness in the compartment two back from gen once and then never again
I'm chocking it up to damp patio rug and good seal never dried out
My issue was with rt side first compartment behind Gas Bottle
This is my tool shed and it was getting wet in there and started to rust my stuff :-(
I emptied it and search around and found a hole cut in the upper left top of the plastic casing (access???)
I covered it with duct tape and she's dry as a bone now
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 01-19-2016, 05:14 PM   #5
Hoglou's Avatar
I refoamed when I reworked the plumbing in the right rear bay by adding hot and cold drain valves and discharge lines (search "Two monkeys... Vs Harry"), now the water tanks drain out the rear of the coach and not where I am standing. I also filled some day light I found at the back of cabinet under the sink when I renforced the pots and pan shelf under the sink.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 02-10-2016, 08:06 PM   #6
I think I found the leak. There is a wire loom snake running out of back end of the compartment just in front of the rear tires. The gray foam guy made a big blob, but only covered half the hole.
leak
