Old 06-16-2018, 07:02 PM   #1
CWW
Question leaning to the right, HELP
HELP, My 2011 Sunseeker 33' long is leaning to the right. On the front it is the same height from the ground to fenderwell. On the back it is 1-3/4" lower on the Right fenderwell that the Left.
I can not see anything that looks out of place. Could it be the body that is out? or could it be the shocks are bad? and if so what can I replace them with?
Chris
CWW is offline   Reply With Quote
Old 06-16-2018, 07:07 PM   #2
SeaDog's Avatar
crawl under and look for a cracked main leaf spring. On my class A it also leaned to the right I had the rear spring re-arched (no broken leafs) and added a spring to bring it to level and never had the problem again. Ride was not affected.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-16-2018, 07:10 PM   #3
CWW
I think there are 5 or 6 stacked up, so what would I be looking for?
Old 06-16-2018, 07:37 PM   #4
SeaDog's Avatar
Look for a crack in the spring leaf it may not be easy to find but take your time and look at each leaf. While you are there measure the difference from the shackle ends to the ground and compare to the other side. It may be the spring is just getting weak. If you decide to have it re-arched the spring shop will give you specifics of where to measure.
Retired Navy
Old 06-16-2018, 09:32 PM   #5
A32Deuce's Avatar
The right spring should look just like the left spring. Get on flat level ground and take some measurements.
A32Deuce is offline   Reply With Quote
Old 06-16-2018, 09:49 PM   #6
Duckogram's Avatar
Do you have Ride-Rite Air Bags?
ILB ( | )
Old 06-16-2018, 10:12 PM   #7
CWW
No air bags, and the springs look the same. What, how and where do I measure?
Old 06-16-2018, 11:03 PM   #8
2012 Solera
Have you checked the weight on each side of the rear? Easy to get uneven side-to-side. May come that way from the factory - you may have to compensate by how you load it up.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-16-2018, 11:35 PM   #9
Last year, our brand new TT started to lean after the 25 miles to tow it home. As it turns out, one of the springs had already "collapsed" by losing its arch. Both springs were eventually replaced under warranty. It happens.
2017 Coachmen Viking 17FQ
2006 Chevy Colorado Z71
Homersimpson is offline   Reply With Quote
Old 06-17-2018, 12:18 AM   #10
CWW
it's empty, 1/4 water, 1/4 gas only
