Old 08-02-2016, 08:39 PM   #11
geeman53's Avatar
[QUOTE=Hoglou;1278636]geeman53, or should we call you king 4560! You can haul anything..[/QUOTE
Just don't call me late for supper !Click image for larger version
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 08-02-2016, 09:42 PM   #12
Big foot all the way. Nothing better. Push auto and let it do its thing.
Pacostaco is offline   Reply With Quote
Old 08-02-2016, 10:12 PM   #13
I like my BigFoot levelers. I find it to be a bit aggressive as it often wants to lift the wheels off the ground, so I usually use it on manual.
firedoctor is offline   Reply With Quote
Old 08-02-2016, 11:24 PM   #14
I have had levelers on my Class A's for over 16 years. Couldn't live without them. Last year, I decided to downsize to a Class C. The model I saw had a Big Foot system, so I ordered my coach with them.
Wayne Lee
Out West Somewhere
2016 Sunseeker 3050DS towing 2006 Hummer H3
WayneLee is offline   Reply With Quote
Old 08-03-2016, 05:50 PM   #15
More frequently than not my tires are off the ground after leveling. Make sure emergency brake is on and it will be fine. The auto setting takes into consideration water run off and are set that way at the factory. So let them do their thing
Old 08-03-2016, 06:08 PM   #16
sgtlm17's Avatar
Your bigfoot levelers can be quite a bit out of calibration from the factory. I recommend using your fridge as point of where to level and recalibrate the levelers. The process is super simple.
2016 Forester GTS 2801QSF
RVHabit.com
sgtlm17 is offline   Reply With Quote
Old 08-03-2016, 06:28 PM   #17
I drove to the factory and paid to have them installed. They level perfect almost all the time. If not I retract and auto level again. Never had to do it more than twice.
Old 08-03-2016, 06:53 PM   #18
Witch Doctor's Avatar
Big foot is a good system about the same as the rest that you can get installed, but I would look at the difference between system 3700.00 not installed is at the pricey end for me for the capabilities. You can get the 4 point level-up for about 3400.00 installed and it will do more the the big foot. I'll attach what each system can do or what they recommend what it can do.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-05-2016, 08:54 PM   #19
17Racer's Avatar
I have and like the Big foot system. Just used them an hour a go, and they work fine. At first I used Auto but now mostly use manual as I stay just on the shy side of perfect which means less lifting.
2014 Forester 2301 - Chevy
17Racer is offline   Reply With Quote
Old 10-27-2016, 01:45 PM   #20
We just returned from White Pigeon, MI where we had Big Foot Levelers installed, at the factory on our SS 2300 and we are very happy with them. They make a huge difference in setting up and tearing down. Thanks for all the recommendations from the group!
lexstone is offline   Reply With Quote
leveling
