Old 04-03-2017, 02:35 PM   #1
Leveling Sunseeler GTS with the Air Rite System
Anybody use the air rite shocks to level their sunseeker GTS when setting up at a site or do you ride up on blocks?
fritzg2 is offline   Reply With Quote
Old 04-07-2017, 11:13 AM   #2
I use blocks on my 3170DS, I set the air in the bags before I leave and don't touch it.
2012 Sunseeker 3170DS (2016-Present)
2014 Hyundai Elantra (TOAD)
Acme EZ-Tow Tow Dolly
2011 Heartland Edge M22 (2015-2016)
2005 Ram 2500 Quad Cab, Short Bed (2015-2016)
2006 Ford F150 Quad Cab, Short Bed (2015)
m000336 is offline   Reply With Quote
Old 04-07-2017, 11:20 AM   #3
How many air valves do you have. I can only find two (ine each side at back of unit inside storage compartments
Old 04-07-2017, 11:34 AM   #4
Just those two. Even if you fill the bags up to their maximum limit you won't get enough of a difference in the two sides to level your rig in a pad that is sloped.
Old 04-07-2017, 12:01 PM   #5
so when weight is added you can't level front to back only the back?
Old 04-07-2017, 05:27 PM   #6
I guess you can level front to back using the bags as well but I think you will find it much easier and less time-consuming to use blocks.
leveling
