Old 06-13-2014, 11:54 AM   #1
lights
The awning light are going out one by one. The 2014 sunseeker 3170 led light string mounted. I through that led was suppose to last a long time. This will be the fourth time that I used the motor home. Is anyone else have this problem?
John and Diana Embrey Texas 2019 Coachmen Mirada 35 KB
cruiserjohn is offline   Reply With Quote
Old 06-13-2014, 12:41 PM   #2
They do last a very long time. Check for water intrusion.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 06-13-2014, 12:53 PM   #3
KyDan's Avatar
See this thread--
LED awning lights.
especially post 5.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 06-13-2014, 01:40 PM   #4
RV Nomad
Mine started going out 2 months after I bought it new from dealer. Mine are Dometic, and I contacted a local Dometic authorized repair dealer near my house instead of the dealer where I bought the unit which is 3 hours away. They agreed to get me the new strip under warranty and allow me to install it myself. Not too difficult, I had to unsolder the old leads and solder on the new strip, then I put shrink tubing over solder joints. Running the new strip into the track was the trickiest part. I had to carefully push it in bit by bit, you can't slide it in. Turned out great. I did notice that the replacement strip was built thicker and heavier than the original. I did the repair last October, still not a single light out.
2013 Sunseeker 2500 TSF
xgzx is offline   Reply With Quote
light
