Old 04-13-2015, 10:34 PM   #1
hockeytownmom's Avatar
Linoleum while driving
While driving home last night, I noticed my linoleum had air under it. All of it, across the entire kitchen/dining area. The air seems to be coming in from under the couch/stove slide. What can I do about this? Shouldn't this be glued down?? Why is there air coming in??
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 04-14-2015, 12:53 PM   #2
Average Joe
MrJoe's Avatar
Ours has done that... Weird, doesn't do it all the time.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 04-14-2015, 01:02 PM   #3
Class C Representative
Joshua Cavitt's Avatar
It is glued down in certain areas. The floor we use needs to be allowed to expand/retract to prevent cracking or pulling up so we don't glue the entire underneath. It is also stapled to the floor along the exterior edges.
Joshua Cavitt is offline   Reply With Quote
Old 04-14-2015, 02:54 PM   #4
ColoradoRick's Avatar
That's exactly what my dealer told me about mine. (I, also, had a few bubble where it would stick up a bit.) But, looking at it this Spring, it looks like the cold made it shrink just a bit.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 04-14-2015, 09:07 PM   #5
Okay about the flooring not being glue, but what about the air?
Kristina & Family
Old 04-17-2015, 10:09 PM   #6
Maybe an opening near a vent? (It should've been glued down around all the vents)
Rick & Karen
Monument, Colorado
Old 04-18-2015, 10:34 PM   #7
I don't have any floor vents.
Kristina & Family
Old 04-18-2015, 10:51 PM   #8
Crockett's Avatar
low pressure in the coach wil lift vinyl. close windows and vents when traveling.
edit: Ill bite...what areas are glued?
Crockett is offline   Reply With Quote
Old 04-19-2015, 01:51 PM   #9
I wouldn't be too concerned about a little air under the floor when driving even though it should be sealed enough on the edges to prevent it from happening. However I would be concerned when driving in rain as moisture could get under the floor which could create mold, warping, or rot conditions. If you can't figure out where it's getting in and seal it then driving with all the windows and vents closed while keeping the cab HVAC on should pressurize the coach and maybe prevent the issue. However I doubt it because the air getting under the floor may not be communicating with the air volume in the coach (unless there are leaking penetrations in the floor) and the pressure in the coach may not affect it.
ATVer is offline   Reply With Quote
Old 04-19-2015, 06:33 PM   #10
benagi's Avatar
I hope you get this figured out. I don's think it would be normal for any motorhome with lino to lift while driving, even if you do have the windows open. There must be something wrong here.
We ordered a 2016 3170ds with all lino, and I hope we don't run into the same problem you are having.
benagi is offline   Reply With Quote
