Old 02-16-2015, 05:40 PM   #21
Boso's Avatar
Thanks it took 3 times but I got it I might be little slow sometimes and a lot slow the rest Thanks
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 02-17-2015, 09:51 AM   #22
hockeytownmom's Avatar
Originally Posted by bclemens View Post
Also just to clarify those with Hydraulic suggestions, the Class C divisions does not run any hydraulic slides at this time.
The 3170 has (2) slide styles.
Living room slide is a Lippert above floor sofa slide.
Bunk room slide (passenger side) is a Lippert Schwintec slide. (has the silver worm gear rails on the slide room exterior walls).
A shear pin issue would only be the living room slide. Sync'ing motors would be the bedroom slide.
Please carry on, now that we're all on the same page (hopefully)
Thank you!!! Any tutorials on how to sync these?
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 02-17-2015, 10:01 AM   #23
fonzie's Avatar
This might help. Also if you go on you tube and type "schwintek" you will get lots of "video's how too"
https://lci1.com/support-in-wall-slide-out
Fonzie
Old 02-17-2015, 10:46 AM   #24
Thanks, I did see that one. I'm also considering disengaging the motors, sliding the slide out completely and reengaging them to see if it will bring it in and if it will then slide out on its own. But dh isn't so keen on this though.
Kristina & Family
Old 02-17-2015, 10:48 AM   #25
Also the rubber seal above the wardrobe is completely off the wall and just sitting on the wardrobe when the slide is in. Need to fix that as well.
Kristina & Family
Old 02-17-2015, 12:46 PM   #26
GM
bclemens's Avatar
Seals jamming up the works would also stop the slide from operating properly.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-17-2015, 06:54 PM   #27
The seal is clear of the slide, we checked that as well.
Kristina & Family
Old 02-17-2015, 07:06 PM   #28
B and B's Avatar
This cold weather would not be best for troubleshooting. I would make sure the Battery is full or charged before starting , anything less that full power would cause issues with the motors. Is it possible something is stuck under the schwintek slide? Kids toy, in our case a dogs toy jammed it up. HTM try the syncing part first before pulling the motors, they are difficult to get at.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 02-17-2015, 10:11 PM   #29
I checked for toys, but there's really not much room for anything to get under it.
Kristina & Family
Old 02-18-2015, 06:30 PM   #30
Okay, I brought the MH home today. Charge the batteries and extended the wall slide. Still only 12", the rear of the slide stops moving after the front of the slide stops. I can also hear a little bit of metal on metal sound as it stops moving. I tried extending and retracting to align them and it's completely aligned when it's retracted completely, but when it goes out again, the rear starts lagging behind again. I also tried holding the button in for 3-5 seconds to reset the zero point, but that didn't help extending. So I'm at a loss.
Kristina & Family
slide
