Old 02-18-2015, 06:37 PM   #31
hockeytownmom's Avatar
Brian, do you know where I can find the slide control box? I want to see if it's giving me an error message.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 02-19-2015, 09:02 AM   #32
GM
bclemens's Avatar
It's screwed to the roof of the cargo box below the slide (I think the same box where the water filter is). That area may now be covered with an ABS box.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-19-2015, 10:13 AM   #33
Thank you, I'm going to freeze my butt off to see if there's an error or loose wire.
Kristina & Family
Old 02-19-2015, 01:12 PM   #34
I recently experienced a similar issue on my 2011 3170 and maybe what I found will give you another area to look at. On mine the screws that hold the 4 rails on to the room came loose to the point that the heads on some came off and others backed out far enough to cause the slide to jam and one of the v rollers came off and also busted one of the gear carriers so I am doing a complete rebuild of the slide and learning a lot in the process. so that being said,in one of your previous post you said you wanted to disengage the motors and force it out witch is exactly what I did and I believe that is what caused some of my damage due to the fact I could not see the screws that had backed out. If your still under warranty I would let them fix it.
lbrunning is offline   Reply With Quote
Old 02-19-2015, 01:50 PM   #35
Yeah, we're going to take it in tonight or tomorrow. It's just too cold out to walk from the house to the camper, let alone stay out there looking for stuff.
Kristina & Family
slide
