Old 06-15-2013, 12:26 AM   #11
Sgt. Schultz's Avatar
Good stuff -- I would tape the latch so it doesn't snag again until you can figure out what happened.
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 06-15-2013, 12:54 AM   #12
That would probably be wise. Thank you.
forestermom is offline   Reply With Quote
Old 06-15-2013, 05:39 AM   #13
DAISY BOYKIN's Avatar
A simple fix------------
Remove door knob assembly, go to Lowe's or Home Depot, purchase same type door knob assembly, re-install new assembly. Should correct your problem rather fast!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-15-2013, 05:48 AM   #14
Herk7769's Avatar
I have another idea.
Is your camper level?
ANY twist in the camper's frame will "rack" the door in the frame and cause it not to open. Using a carpenter's level, check the floor left to right and front to back. The bubble must be between the two lines.
HAM CALLSIGN - KC3FFW
Old 06-15-2013, 06:10 AM   #15
fonzie's Avatar
How did he get it? Just very hard to turn handle?
Fonzie
Old 06-15-2013, 07:25 AM   #16
Jack of All Trades
RJHuser's Avatar
In addition to what Herk said, I've cranked the stabilizers to hard in effect "arching" the frame, causing the door to either not latch, or being very hard to turn the door knob.
Now that the door is open, does the door knob work?
Try retracting the stabilizers and see if the door and door knob works OK
Rick
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 06-15-2013, 07:37 AM   #17
Roll's Avatar
Mind sharing how he did it?
We might find ourselves in the same boat...err RV. :-)
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 06-15-2013, 07:41 AM   #18
clancythecamper's Avatar
I have had issues with doors when the level was off before, that was my first thought too. Perhaps in the future, open the door slightly before doing the leveling? (if it was that issue, anyway)
clancythecamper is offline   Reply With Quote
Old 06-15-2013, 07:48 AM   #19
Mega Member
Sounds like a frame jamb issue and/or the internal lock mechanism was improperly installed or had a mechanical failure. Also, if this happens, perhaps you can pop up the hing pins on the other side of the door to get it open in an emergency.
rgarner is offline   Reply With Quote
Old 06-15-2013, 07:50 AM   #20
Sounds like an arched frame to me, I hope they are not using the stabilizers to level the trailer ....
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
