Old 06-14-2013, 11:26 PM   #1
Locked out of bathroom!
Please help. This is our second time out with our new 3170. We arrived at the campground after hours unfortunately. Well we have ever thing set up, go to use the bathroom and the doorknob will not budge. Someone please tell us how to get this door open without pulling it out. I didn't even realize there was a lock on the door.
forestermom is offline   Reply With Quote
Old 06-14-2013, 11:34 PM   #2
timarti's Avatar
Shot in the dark, but does the doorknob have a hole in it that you can stick in something skinny and pointy to pop the lock, assuming there is one?
Tina & Ted & pooches
2012 Ford F-150 XLT 5.0L V8 4x4 with tow package
Andersen WD hitch with sway prevention
2012 Rockwood UltraLite 2304s trailer
timarti is offline   Reply With Quote
Old 06-14-2013, 11:39 PM   #3
Nope no hole. No anything just a knob with nothing. I can't understand how this happened.
Old 06-14-2013, 11:53 PM   #4
Sgt. Schultz's Avatar
Does it look something like LSK-C2-OWB ? If so it may be best to call dealer for quick advise - failing that call the warranty folks - there should be a quick fix for this
PT Avenger 33BHS-TE
2020 f-250
Sgt. Schultz is offline   Reply With Quote
Old 06-14-2013, 11:55 PM   #5
Yes but the screws are on the inside.
Old 06-15-2013, 12:10 AM   #6
depending on the structure you may be able to pry gently between the lock and frame to open - with a small screw driver or try a credit card or similar object to release the catch
PT Avenger 33BHS-TE
2020 f-250
Old 06-15-2013, 12:10 AM   #7
We need in there like now. I wonder if they'll cover a hacksawed door?
Old 06-15-2013, 12:11 AM   #8
:-) trying to find some humor in this. What an experience!
Old 06-15-2013, 12:17 AM   #9
Thanks for trying to help. This lock is not budging. We've tried a hanger, credit card, butter knife.
Old 06-15-2013, 12:18 AM   #10
My husband finally got it. No lock on the inside either. That was really crazy!
Old 06-15-2013, 12:26 AM   #11
Good stuff -- I would tape the latch so it doesn't snag again until you can figure out what happened.
PT Avenger 33BHS-TE
2020 f-250
Old 06-15-2013, 12:54 AM   #12
That would probably be wise. Thank you.
Old 06-15-2013, 05:39 AM   #13
DAISY BOYKIN's Avatar
A simple fix------------
Remove door knob assembly, go to Lowe's or Home Depot, purchase same type door knob assembly, re-install new assembly. Should correct your problem rather fast!
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 06-15-2013, 05:48 AM   #14
Herk7769's Avatar
I have another idea.
Is your camper level?
ANY twist in the camper's frame will "rack" the door in the frame and cause it not to open. Using a carpenter's level, check the floor left to right and front to back. The bubble must be between the two lines.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-15-2013, 06:10 AM   #15
fonzie's Avatar
How did he get it? Just very hard to turn handle?
Fonzie
Old 06-15-2013, 07:25 AM   #16
Jack of All Trades
RJHuser's Avatar
In addition to what Herk said, I've cranked the stabilizers to hard in effect "arching" the frame, causing the door to either not latch, or being very hard to turn the door knob.
Now that the door is open, does the door knob work?
Try retracting the stabilizers and see if the door and door knob works OK
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 06-15-2013, 07:37 AM   #17
Roll's Avatar
Mind sharing how he did it?
We might find ourselves in the same boat...err RV. :-)
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2018 Wrangler Unlimited Sahara (JKUS). Many upgrades, additions, mods, and changes to the coach.
Roll is offline   Reply With Quote
Old 06-15-2013, 07:41 AM   #18
clancythecamper's Avatar
I have had issues with doors when the level was off before, that was my first thought too. Perhaps in the future, open the door slightly before doing the leveling? (if it was that issue, anyway)
clancythecamper is offline   Reply With Quote
Old 06-15-2013, 07:48 AM   #19
Mega Member
Sounds like a frame jamb issue and/or the internal lock mechanism was improperly installed or had a mechanical failure. Also, if this happens, perhaps you can pop up the hing pins on the other side of the door to get it open in an emergency.
rgarner is offline   Reply With Quote
Old 06-15-2013, 07:50 AM   #20
Sounds like an arched frame to me, I hope they are not using the stabilizers to level the trailer ....
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
