Old 04-11-2018, 07:38 PM   #1
Looking for good reviews on 3010DS
We are buying a 2018 Sunseeker 3010DS tomorrow, and I've been looking for good reveiws. Are there any?
PortCityThrift is offline   Reply With Quote
Old 04-11-2018, 08:00 PM   #2
Frankie Z's Avatar
I took delivery in February
First trip April 23
I’ll let you know.
Will say tires no longer Michelin they are hankook
Toilet no longer porcelain but I knew that going in. Also drawer latch broke already, I think I opened and closed it about 3 times. I expect that though, they are cheaply made. Bought a four pack, hope it gets me through the year. Had a 2014 2650s I traded in. No problems at all with that model. Hoping 3010DS continues problem free. Let me know how you like yours once you break it in.
Frankie Z is offline   Reply With Quote
Old 04-11-2018, 08:44 PM   #3
Duckogram's Avatar
Welcome to the FRF and good luck with your purchase tomorrow.
ILB ( | )
Old 04-11-2018, 11:16 PM   #4
Adult Member
We purchased a 2017 in January 2017. Love it. We also h ad a drawer latch break but dealer fixed it. We have added maxair vents and a few other mods. Fyi- satellite hook up is located on the roof, then tv hooks up on brown outlet above door. Not the one for the antenna. Took a big trip through 2 provides of Canada & 19 states last summer. Handled good in mountains.
punkinpie is offline   Reply With Quote
Old 04-12-2018, 07:12 AM   #5
ChucknBecky
lckspt's Avatar
2017 purchased in Dec 2016. 6800 miles so far. Little things, a bit noisy with the foam insulation in the roof. Added wireless remote control air pump for airbags because of where the schrader valves are. Have an adapter to bayonet fitting on gray/black tank drain. If pebbles or rocks get in between the segments of expensive sewer hose it will cause holes. This will adapt the cheaper hoses as a backup.
lckspt is offline   Reply With Quote
Old 04-12-2018, 08:56 AM   #6
Why do you have the adapter on your sewer outlet? I don't understand, possibly b/c I haven't used mine yet. I got a plug for the coach side of the hose, I intended to disconnect it, plug the end, and stick it in a bin when not in use.
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 04-12-2018, 09:30 AM   #7
Duckogram's Avatar
I too purchased an adapter. It basically is just a short collar that goes from cam lock to the old standard bayonet so you can use legacy equipment.
ILB ( | )
Old 04-12-2018, 09:32 AM   #8
I think I have one from the dealer (or FR) somewhere in my rig. I'm pulling it back out of storage this weekend to put Hellwig sway bars on the front and rear. I'll try to find the plug. I DID buy the extension Waste Master hose, so I doubt i'd need the bayonet.
Old 04-12-2018, 12:48 PM   #9
ChucknBecky
lckspt's Avatar
Well for one thing the new hose and connector which I love is expensive and is not in any of the camp stores that I have seen. A new hose cost around a hundred bucks.....take good care of it....but if you spring a leak like we did in Florida last year all you have to do is to use the adapter and you can use the cheap hoses at Walmart or other place that sells camping and RV supplies.
Old 04-12-2018, 01:37 PM   #10
That WasteMaster extension WAS expensive.
