Old 04-10-2017, 01:07 AM   #1
Hoff48's Avatar
Looking to auto-adjust my Ride-Rite air suspension.
I was thinking it might be cool to add a compressor and a control system to maintain and adjust my air suspension. I was wondering if anyone has done this, and what I would need to do this.
mrhoff48
2015 Sunseeker 3170ds.
just bought in Feb 2017. (first RV)
2017 5 days camping so far.
Hoff48 is offline   Reply With Quote
Old 04-10-2017, 08:01 AM   #2
RedLdr1's Avatar
I've considered that option as well. Firestone offers kits, See Here, to adjust the air bags and they can also be used with accessories as a on board air compressor for inflating other "stuff". But they are fairly expensive...
Most off road Jeep type shops will offer similar products so you might want to check with them as well.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350
RedLdr1 is offline   Reply With Quote
Old 04-10-2017, 08:23 AM   #3
Land of the Midnightsun
jjSpeedwagon's Avatar
I installed an air-lift system on our Concord. ( e-450 or f-450 ) and I love it. You can change your inflation on the fly to adjust for rough roads or inflate one bag more psi than other bag. Cost was 300$ I think.
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 04-12-2017, 05:58 PM   #4
What would be a good starting pressure
for the ride rite air bags? I have a 2017 2800 sunseeker and will be towing a 2002 Toyota Camry. The dealer said they aired it up to 70psi. I am thinking I may need a little more when towing.
2017 Sunseeker GTS 2800 QS
2017 Jeep Grand Cherokee toad
1987 Sunstream (sold)
Retired BTC USN
Chesapeake, Virginia
charles l is offline   Reply With Quote
Old 04-12-2017, 06:22 PM   #5
grumpy0374's Avatar
We tow a Subaru XV with our Lexi. I run 70 psi in the bags. If your ride is OK with the 70 psi, you shouldn't need to add more if your towing. Towing a toad dosen't really add any "weight" to the rear of your rig. Weight of the tow bars is negligable, and your "towing" not "adding weight"
Also, remember, the bags are rated for 100 psi.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 04-12-2017, 06:42 PM   #6
You could probably use semi truck air bag adjuster. It just adjust for height, depending on the load.
Steve29rlx is offline   Reply With Quote
Old 04-13-2017, 09:31 AM   #7
RedLdr1's Avatar
I pull a Ford Edge with our GTS2800 and have the airbags set at 55PSI. I've always tried to use the minimum amount of air pressure necessary to adjust for the load. I've found that the more PSI you use the harsher the ride.
Wayne
Old 04-23-2017, 09:16 PM   #8
I always have my air bags at 80psi, carry a bike rake with 2 bikes also I clear the driveways no problems and not a stiff drive while on the road..
goots is offline   Reply With Quote
suspension
