Old 04-01-2015, 01:26 PM   #1
Puzzlme's Avatar
Loose Slide Topper
The Living room slide on my 2013 3010DS has a small sag. Should this be tightened and if so, is there an easy way to DIY?
http://rhodaventure.com/
2013 Sunseeker 3010DS
2014 - 15,000 Kilometers (9360 Miles) Alberta through the US to E. coast, up into Atlantic Canada, Newfoundland and back.
2015 - 2 great trips so far. Alberta to Oregon coast, Alberta to Shushwap in BC.
Puzzlme is offline   Reply With Quote
Old 04-01-2015, 03:50 PM   #2
Check your anti-sail stop arm. It may be jammed. Both of my toppers came from the factory with only one screw holding the stop arm and I noticed they were bent and not positioned properly. If you are unfamiliar with the configuration, the manual for the toppers should show them.
ATVer is offline   Reply With Quote
Old 04-01-2015, 03:52 PM   #3
Mine started sagging and I put 3 or 4 additional turns in both ends. Time consuming, but not really difficult.
slide
