Old 10-14-2014, 03:50 PM   #1
Low Point Drain
I have an '06 Sunseeker. Underneath on either side are translucent drain hoses. They are not marked. Are these the low point drains? I can't find any drains on the inside of the coach other then the fresh water drain.
biznsa is offline   Reply With Quote
Old 10-15-2014, 07:45 AM   #2
cpaulsen's Avatar
Should be hot and cold water drains. On mine they had colored caps. I installed 1/2" ball valves.
cpaulsen is offline   Reply With Quote
Old 10-15-2014, 08:28 AM   #3
mark0224's Avatar
Sometimes these things are fun to find, I helped an older couple that were having problems, couldn't put water in their tank. The drain valve was open and water kept pouring out of their tank. I finally found a valve way back under their bed that you had to access through a door. I have long arms but had to get my shoulders trough the access to reach this valve. There was no way this old couple would have reached it and spotting it was almost impossible. If it were mine I would have made some sort of handle so you could reach it easy.
Best I could say go to your generic owners manual it should get you close to where they are.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-15-2014, 08:39 AM   #4
mark0224's Avatar
found this for you 2004 Sunseeker 3100 Low Point Drain. Just enter it into the search at the top of the page and go to the thread. There was a guy that had an 06 sunseeker showing the low point drain. Hope this helps.
Old 10-15-2014, 04:13 PM   #5
Thank you kindly, mark0224. That helps immensely.
Old 10-15-2014, 11:46 PM   #6
mark0224's Avatar
Your welcome
drain
