Old 10-09-2017, 11:24 PM   #1
Low Point Drains for 2014 Sunseeker 3170DS
A few months ago we bought a 2014 Sunseeker 3170DS. Itís time to winterize and this will (obviously) be my first time with this unit. I am looking for ALL the low point drains and the fresh water drain. I find two BLUE low point drains behind the passenger side rear tire (and behind the exhaust pipe); one with a cap and one without a cap. I cannot find a RED low point drain. Can anyone help me decipher what I have found (and what I may not yet have found)? Any help would be greatly appreciated!
The Happy Hopkins
Travel Companion: Nora "The Anorable"
mhopkins is offline   Reply With Quote
Old 10-10-2017, 07:17 AM   #2
I had a 2014 2300. The low point drains were located just like yours, except the cap was on the red line. If you don't find the red line, it may be the capped blue line. Just my opinion.
GMax is offline   Reply With Quote
Old 10-14-2017, 09:57 PM   #3
Garrette's Avatar
There is only one low point drain on the 2014 3170. The low point drain is the one with the cap. The other line is for the fresh water tank drain. The fresh water tank valve is a quarter turn valve. If you reach behind the panel, to the right of the filter, you will feel it. A bit difficult to turn but manageable. Use your left hand.
To drain water heater, pull the anode.
To drain, open all spigots and drain via low point drain. Be advised, it will not drain all of the water. You will need to use the air blowout method or antifreeze to insure you have winterized.
I use blowout method. Try not to exceed 30psi. Your toilet can be a bit of a pain to blow out. Just keep cycling the foot valve to get the water out. Remember your outside shower. Easy to forget. I remove the hose and blow out. Water filter should be removed and the canister put back before the blowout. After you are satisfied that all is good, remove the water filter canister and just leave it in the bay. Water in the threads can freeze and crack your water filter canister.
I pour the RV pink antifreeze in all drains. I drain the black and grey tanks and add a generous bit of antifreeze to protect the drain valves, or simply leave the valves open.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 10-15-2017, 11:47 AM   #4
I did my winterization after looking at a good variety of blogs and videos (the post above is the most helpful/concise, IMHO). I used the (1) drain, (2) blowout, and (3) antifreeze-in-lines method. Seemed a bit like overkill. If antifreeze in the lines, then why blowout? If blowout, why antifreeze in the lines (of course antifreeze in p-traps/toilet)?
The Happy Hopkins
Old 10-15-2017, 12:18 PM   #5
Citrus County, Fl.
GL1800Rider's Avatar
"To drain water heater, pull the anode"
The instruction above is for the Suburban water heater which is no longer used. The Atwood does not utilize an anode rod. Just remove the plastic plug at the lower left and let it drain
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 10-15-2017, 02:19 PM   #6
Garrette's Avatar
You are correct. I would consider them to be 2 methods. I only use the antifreeze in the drains and a bit in the grey and black tanks. The antifreeze does not evaporate as readily and just gives me a trap seal from the tank smells getting into the coach. A little antifreeze in the toilet, covering the ball and seal will help the seal stay playable.
On my water heater, I remove the anode, rinse out the tank and leave the anode out till spring.
If you opt for the antifreeze method, I do not think blowing out the water first is necessary. All you are doing is replacing water with antifreeze. On our 2014 3170's, we do not have a suction point in front of the water pump to draw antifreeze into the system. New RV's have this nice feature. Without it, we need to pour antifreeze into our fresh water tank and than pump it around. I am not willing to do this and have not added a tee, valve and suction line to do this.
Which method is best? I do not know but, one thing is for sure, you have winterized, that's for sure. I will take overkill protection from freeze ups anyway.
FYI, the Dometic toilets have a freeze plug to tell service that the toilet was frozen. Buddy of mine froze his TT and tried to get it all repaired under factory warranty but was denied due to the toilets freeze out plug.
Old 10-15-2017, 10:22 PM   #7
I was told there is (1) a city water check valve and (2) a toilet check valve that needs to be blown out. So, Ö (1) I located the city water check valve behind the filter screen no problem. No way to blow it out since my compressor needs to be connected to the city water inlet, so I just pressed it. Any more that I should do? and Ö (2) I was unable to locate a toilet check valve. Is this the freeze plug you mention? Or should I look further? Thanks for any counsel!
The Happy Hopkins
Old 10-15-2017, 11:11 PM   #8
If you don't blow out first, you will be diluting the antifreeze and therefore expect to use a bit more in order to flush out the water. Not much contention here.
If you only blow out and don't use antifreeze, SOME people claim you will freeze (i.e., damage) something if you get a "hard freeze." This subject causes a bone of contention, similar to gas vs diesel. I live in northern Illinois and we usually get -10 to -20 deg F (-23 to -28 deg C) for 2-3 weeks in the winter; I'd call that a "hard freeze." I've been doing it for over 5 years. Never had a problem. You DO need to make sure you do a good job of blowing out the water. If you're not confident that you have, go with the antifreeze.
2011 Traverse LT, 3.6L, FWD
Old 10-18-2017, 08:48 AM   #9
Hoglou's Avatar
dump the caps
Beating the dead horse, but if you loose the cap you are out of the water business. We replaced ours with valves.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 10-18-2017, 09:13 AM   #10
MNtraveler's Avatar
I'm sorry, but surely there is a hot water line low point drain. Just draining the water heater does not drain the hot water lines.
Can someone tell OP where the hot water low point drain is on this model?
(Someone did mention that it may be the "other" blue tube but that seems unlikely that someone would have changed it from red to blue that that "other" blue line may be the fresh water tank drain which may have a valve not a cap.)
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
2014, 3170, drain, sunseeker
