Old 05-25-2011, 08:40 AM   #1
zook's Avatar
LP Bracket Anchor Point...
Using the LP tank bracket for an anchor point.
Iím looking for a place to attach a U bolt, spring, short chain as a anchor point for a dog cable.. on past campers Iíve used the bracket on the bottom of the awning leg, or the step frame work. On my new Sunseeker 3120 the only practical place I can find is a bracket on the LP tank,, any reason why I should NOT use this? short of drilling a hole to attach a eye bolt through the wall what do you guys suggest? I like clean and simple and really do not want to drill holes. The dog is a 75# Catahoula and does not yank and pull on the cable but has to have one.
Thanks in advance.
zook is offline   Reply With Quote
Old 05-25-2011, 01:12 PM   #2
GM
bclemens's Avatar
My only concern would be chaffing on the tank or hoses. The LP support is tested to 7 times its weight, full. Plus , anytime you can avoid LP, the better.
There should be some seat belt bolts under the sofa.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-26-2011, 06:51 AM   #3
KyDan's Avatar
My advice is get a 1/4 inch galvanized or plated eye bolt and drill
thru your tongue and install the eye bolt.
It's a 5 minute job, not even a one beer job
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-26-2011, 07:23 AM   #4
zook's Avatar
It's a class C not a TT. that's my problem. no tongue, no steps, no bottom bracket on the awning, the LP compartment is the closest to the door and does not need a key to open.
Old 05-26-2011, 10:17 AM   #5
caper's Avatar
Could you use one to the ground stake tieouts. Thatway you will not have to drill in to your unit.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
