Old 10-06-2016, 04:59 PM   #1
m2100 fresh water tank drain
I just purchased a 2003 2100. I can't find any drains for the fresh water tank or fresh water system in general. I am hoping someone might know if there are any and where to look or does this older system require emptying the tank by using the pump.
Trumanjr is offline   Reply With Quote
Old 10-06-2016, 06:38 PM   #2
Iggy's Avatar
Being you have a 2003 which doesn't help much I can only give you some guesses.
1. I would look under your rig and try to find any hoses hanging down with or without any caps.
This is usually where the water tank drain is as well as low points for draining everything for winter storage.
See picture.
2. If you find the water lines try to figure out what compartment the are below and open that compartment and look for a valve.
Many times the compartment is not easily visible but usually is close to the filter and water fill on the outside.
That is the best I can tell you with little information.
2012 Georgetown XL - 378TS
Iggy is online now   Reply With Quote
Old 10-06-2016, 06:42 PM   #3
Iggy's Avatar
I also just found this video on YouTube but its for a new Sunseeker but may help you.
Old 10-14-2016, 04:25 PM   #4
Sunseeker 3010DS
Look in the compartment directly under your fill cap the compartment may have a removable rear panel on the back wall your valve and water filter should be there if not the tank may have a plug or hose with a plug. But all should be under or very close to your fill cap.
slamac is offline   Reply With Quote
210, drain, fresh water, tank, water, water tank
