Old 02-06-2015, 12:08 PM   #11
I do love the rhino flex hose and I have the same problem on my 3170DS compartment. The simple solution is to twist the un-lock ring on the Rhino fitting and unscrew it from the pipe. The hose will fit thru the opening and then you can re-attach the end.
2011 SunSeeker 3170DS
hunt247 is offline   Reply With Quote
Old 02-08-2015, 08:18 AM   #12
Just trim a little bit off of each tab and it fits with no problem.
Kevin & Judy is offline   Reply With Quote
