Old 05-25-2018, 12:57 PM   #1
Manually Closing Living/Dinette Slid
After removing the hitch pin is this the correct bolt to turn to close the slide?
Kim
bayoubelle is offline   Reply With Quote
Old 05-25-2018, 04:54 PM   #2
grumpy0374's Avatar
You probably don't need to remove the pin. Just get the proper size socket and go to it.
Same type of set up on our Lexington. I carry a 1/2 inch drive with the proper socket (can't think of the size right now) just for the chance I might need it.
Pin is there to prevent the inside assembly from pulling through the floor should the motor/gearbox/frame assembly comes loose. It won't pull the manual bolt up thru the floor.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 05-25-2018, 08:03 PM   #3
Yes, that is what mine looks like too. I did not remove pin for my test run on it.
sask is offline   Reply With Quote
Old 05-25-2018, 08:53 PM   #4
I forgot to say this is on a 2017 3010DS.
I would think they would be the same.
Thanks for the responses.
Kim
Old 05-26-2018, 08:21 AM   #5
Mine is a sunseeker 2013 2650s. I was surprised at how easy the slide moved using this bolt.
Old 05-26-2018, 08:35 AM   #6
One of my favorite RV bloggers had a slideout issue a couple of years ago and he posted interesting blog and video. He has a different c class but many of his blog entries are pretty interesting and relevant.
http://www.rvwithtito.com/articles/h...-your-rv-slide
Old 05-26-2018, 04:19 PM   #7
Frankie Z's Avatar
I have a 3010 DS also where is that bolt located?
Frankie Z is offline   Reply With Quote
Old 05-26-2018, 05:48 PM   #8
It’s located in the long compartment (under the slide) on the drivers side.
Kim
Old 05-26-2018, 06:03 PM   #9
Did you close your slide all the way in on your test run?
Also, could using this method damage the slide motor?
Kim
Old 05-26-2018, 06:21 PM   #10
No, it does not damage the motor. It is there for that purpose. Do NOT remove the pin, that is how the fitting drives the shaft. I think it requires a 3/4 inch socket. You may already have a manual crank for the tongue jack that will fit it.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 05-26-2018, 07:28 PM   #11
Frankie Z's Avatar
Thanks good to know
Old 05-26-2018, 07:54 PM   #12
I have a 2015 2861DS. I saw that bolt inside one of the compartments on the driver side.
Questions:
1. Is there a release lever anywhere that we need to release before cranking the slide IN/OUT?
2. Which direction to SLIDE IN and OUT? (Clockwise vs. Counter Clockwise)?
3. How about the BEDROOM slide out? Where is the manual crank located?
ADOR is offline   Reply With Quote
Old 05-26-2018, 07:57 PM   #13
Mine was closed when I started. I moved it about a foot and moved it back closed. It was obvious when it closed because of the pressure to turn the bolt.
Rotating an electric motor should not harm it.
The biggest danger would be trying to move a jammed slide and cranking too hard on the bolt. This could damage the gears in the slide mechanism or perhaps the entire mechanism. I would say that if the bolt rotates easy and the slide moves easily, you should be fine.
I would stay away from using a drill to rotate the bolt... unless to set the clutch down low so that it would disengage if got difficult to rotate.
Old 05-26-2018, 08:16 PM   #14
Questions:
1. The bolt is actually attached to the mechanism... no release mechanism.
2. If you can safely watch the bolt while the slide moves, then you will know. Otherwise try it. It should turn easily.
3. Does the bedroom slide extend to the floor? If yes and there are gear strips underneath the slide then the motor is mounted somewhere underneat the slide. If not the look at slide when it is extended. If there is a gear strip on the side of the slideout near the top then the motor is mounted near the top and needs to accessed using different method.
Old 05-26-2018, 08:19 PM   #15
Lots of talk here and need to stress the following... If the slide is damaged or out of alignment, do not crank on the manual override and damage it too. If the manual override turns easy and the slide moves easy... then okay.
Old 05-28-2018, 06:15 PM   #16
All good information.
Kim
manual
