Old 05-25-2018, 12:57 PM   #1
Manually Closing Living/Dinette Slid
After removing the hitch pin is this the correct bolt to turn to close the slide?
Kim
bayoubelle is offline   Reply With Quote
Old 05-25-2018, 04:54 PM   #2
grumpy0374's Avatar
You probably don't need to remove the pin. Just get the proper size socket and go to it.
Same type of set up on our Lexington. I carry a 1/2 inch drive with the proper socket (can't think of the size right now) just for the chance I might need it.
Pin is there to prevent the inside assembly from pulling through the floor should the motor/gearbox/frame assembly comes loose. It won't pull the manual bolt up thru the floor.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 05-25-2018, 08:03 PM   #3
Yes, that is what mine looks like too. I did not remove pin for my test run on it.
sask is offline   Reply With Quote
Old 05-25-2018, 08:53 PM   #4
I forgot to say this is on a 2017 3010DS.
I would think they would be the same.
Thanks for the responses.
Kim
Old 05-26-2018, 08:21 AM   #5
Mine is a sunseeker 2013 2650s. I was surprised at how easy the slide moved using this bolt.
Old 05-26-2018, 08:35 AM   #6
One of my favorite RV bloggers had a slideout issue a couple of years ago and he posted interesting blog and video. He has a different c class but many of his blog entries are pretty interesting and relevant.
http://www.rvwithtito.com/articles/h...-your-rv-slide
Old 05-26-2018, 04:19 PM   #7
Frankie Z's Avatar
I have a 3010 DS also where is that bolt located?
Frankie Z is offline   Reply With Quote
Old 05-26-2018, 05:48 PM   #8
Itís located in the long compartment (under the slide) on the drivers side.
Kim
Old 05-26-2018, 06:03 PM   #9
Did you close your slide all the way in on your test run?
Also, could using this method damage the slide motor?
Kim
Old 05-26-2018, 06:21 PM   #10
No, it does not damage the motor. It is there for that purpose. Do NOT remove the pin, that is how the fitting drives the shaft. I think it requires a 3/4 inch socket. You may already have a manual crank for the tongue jack that will fit it.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
manual
